Buying a turntable
Posted by: John on 07 June 2001
If you're near a dealer, why not pop in and listen?
Phil
You have lots of choice and at the moment it is a buyers market. A good TT is better than most CD's, its one of lifes big secrets.
I have a Garrard 401 which is a fairly heavy and large TT but they are ultra reliable and they need hardly any maintenance or set up. They go on and on and on.
They can be refurbished by several small specialist firms and I have recently purchased a Loricraft plinth which is hand crafted in 1.125" solid American Ash wood by a cabinet maker and this results in a superb looking TT which sounds great. The size is 21" x 18" so it is a chunky thing.
I have had dealers listen to this TT and they have indicated that it sounds better than a LP12.
The standard of engineering is superb, for instance, the factory took 6 working days to balance the platter correctly. They were dropped 4 ft to test shock resistance....you do that to a LP12 and its ready for the grave.
These like other TT's are selling for fairly low sums and now is the time to get one.
Loricraft have a few pics and info and their web site is www.garrard501.com which is well worth a look.
I wish you well in your search.
Mick
Forget an LP12. As Mick says if you drop one it's ready to meet its maker. Even if you don't drop it, just play a record, compare it with your CDS and you will realise that it is nostalgia redefined. It's a bit like voting for that complete dillon William Hague.
However, if you are prepared to free your mind, I suggest you listen to a Garrard, Well Tempered Classic or Reference, Rega P9, Roksan Xerxes 10 (and TMS), with either a SME V or ARO (forget the Artemis)or a Michell Orbe (I heard one of these beasties recently and it is marvellous).
If you are feeling a bit more adventurous have a listen to the Platine Verdier or the Simon Yorke. Forget any SME of any incarnation. I have heard the Model 10 and 20 and feel it is the 'Audiolab' of turntables - brilliant at sonics but emotionless.
cheers
Dev
After much deliberation and (believe it or not) pressure from my girlfriend, we bought our first TT, a Rega 25, a couple of weeks ago.
It's taken those two weeks to "click in" but now it's giving my CD3.5 with FC2 a run for it's money! Well worth it - but the new vinyl's costing me a fortune!
Buy a TT you won't regret it.
Jay
[This message was edited by Jay on FRIDAY 08 June 2001 at 01:10.]
In case you didn't realise, this is an example of Dev's subtle sense of humour - in fact, he can't wait to sell his WTT and buy another LP12 - he just hasn't yet admitted it to himself.
Seriously, even if the LP12 isn't as good as the WTT [and I haven't heard the WTT long enough to have an opinion on which is better] there are very good reasons to consider an LP12. Secondhand LP12s are often available at very good prices, and any post 1984ish LP12 (with braced plinth) can be fully upgraded to current spec. [I think all earlier LP12s can be upgraded to almost current spec].
Whichever turntable you choose, I think something worth bearing in mind is that good CD players and turntables don't have the same set of strengths and weaknesses. Don't expect any turntable to be able to do everything your CDS can, but do expect any reasonable turntable to do some things better.
I suppose I'm a bit of an extremist but when I compared my then Lingo-less LP12/Ittok/K9 with a CDS1 (through a Naim pre/power with SBLs) I actually preferred my turntable, even though the CDS1 was better in almost every respect!
--Jeremy
Most decent turntables should beat the CDS1 - no slur on the capabilities of the CDS1, more a statement about the limitations and musicality of vinyl. AN LP12 represents excellent value and I'd have no hesitation getting another, although in my case I want to hear all the contenders as well...
John
Go on don't be shy.
If you want low maintenance and cheap, it's hard to beat a Rega P3 with Elys cartridge. Basically a set it and forget it unit for a lot less than $1,000 used. There are a few used ones on Audiogon. This modest set up should out do your CDS1.
Recommended by Michael Fremer, and Janet Dudley. Who could ask for more?
If you like what you hear you can then unload it and get the real deal like a Rega P9 or a fully Naimed(or Linned) LP12. Of course you'll end up with the endless cartridge wars the you invaraibly see on the Forum.
You'll also be able to read and understand all those endless write ups by Michael Fremer on cartridges( and turntables). Where does this man find the time to test as many cartridges as he does?
Arthur Bye
Next I did another A/B comparison between the P25 of the same track and a CD version on my CD5/FC2.
It was close. If anything the CD5 made the guitars sound cleaner and more dynamic, but the timing of the P25 was slightly better. A CDX will probably just beat the P25 overall. That will be a 700 GBP turntable, ready-to-play, with cartridge, + 150 GBP for the Rega Fono phono stage, versus a 2400 GBP CD player.
Oh, and one more thing, my P25 "dropped" four feet when the shelf on which it was placed fell off the wall. The lid scattered across the room in lots of pieces and the "picture frame" surround had to be reattached. Note that the above tests took place AFTER this damage occured and did so partly to check its effect on the turntable's performance against possible degradation as a result.
[This message was edited by Steven Toy on FRIDAY 08 June 2001 at 03:19.]
I will defer to your first hand experience with the P3. My only reference point is my P9/Grado Reference, which easily outplays my CDS2.
I know that the P3/Elys is a step down, but I never thought it would be that much.
Arthur Bye
Vinyl does produce a better sound for less money, but let's not take the p***!
Personally I'm for a non suspended design, such as Rega, Nottingham Amalogue, Clearaudio ... the list not exhaustive.
Mick's comments about a Garrard, I whole heartedly endorse, not that I'd want to drop it anywhere near my person. The Garrard may take up some space when properly installed in an appropriate plinth, but it delivers music in neutral and 'organic' way. It times beautifully.
Peter
So buy it 2nd hand for next to nothing - I just bought 21 old faves in good condition for £15.
Set-and-forget turntables:
Well Tempered. American, quirky design that works. Great resolution, pace, frequency extremes. Occasionally can sound uninvolving, but magnificent most of the time. £2000 - £5000 plus cartridge.
Rega. British minimalist design school. Very good pace rhythm and timing - accurate rather than loose. The top P9 sometimes sounds smaller scale but perfectly formed - just like a jewel. £200 - £1700 plus cartridge.
Wilson benesch Full Circle. British circular deck with no cover. Fast pacey sound, not particularly big on scale and can sound dead in the wrong system, but absolutely fun in the right one. £2500 including cartridge (if memory serves)! I've heard it best with its own cartridge - Dynavectors did not a happy match make so it seems quite dependant on the 'package solution'.
Michell. Set the suspension once and fettle it once every 5 years. The only high-end suspended design in the set-and-forget category, thanks to its tremendous engineering. Beautifully built, excellent materials and execution. Big expansive sound, but not the fastest around, not your PRAT machine as such, especially with the basic power supply which makes it really suffer. £750 - £2000 plus arm & cartridge. Best arms are SME IV or Wilson benesch Act 0.5 for the Gyrodec and SME V for the Orbe. Also heard that the ARO is a good combiation on the Gyro.
Audio Note TT1. Based on Systemdek IIX, but with major modifications. Suspended chassis. Swings well and accomplished. £750-ish inc arm (I think).
Fettling decks - ones that need occasional servicing (once a year or maybe more)
Linn LP12. Archetypal Naim companion. Various arm and power supply combinations from multiple manufacturers. Great rhythm and swing. Famous for its euphonic mid-bass colouration which is addictive in the long term. Accomplished yet frustrating. Fantastic when on song, matchwood when out of tune. Old decks (pre'86) go out of tune quickly (6 months). New decks much better at holding tune for up to 18 months. Old decks can be brought up to new spec (except pre'86 models which don't have the corner braces to stop plinths warping). Expansive, rhythmic, not the biggest scale. Setup is a black art so ensure you have an experienced local dealer or that you like to dabble.
Audio Note TT3. Classic 3-point suspension system, 3-motor deck. Takes a variety of arms and cartridges. Keeps its tune better than the LP12. Needs fettling (but it's fairly obvious how to do) every 18 months to 2 years. Fabulous pace and rhythm, very good resolution (not quite in Well Tempered Reference class), hugely involving listen. Expansive, large scale performance with great swing - a bit like an LP12 on steroids without the mid-bass colouration and easier setup. Recommend Audio Note arms or Graham, and Audio Note cartridges but possibly Dynavector depending on arm. £2000 - £10000. Models upgradeable as and when you feel like or have the money all the way to the Reference, excluding changing the external finish of course! This is the one I want I think, but I can't afford the bugger...
Frank.
[This message was edited by Frank Abela on FRIDAY 08 June 2001 at 12:07.]
You said concerning LP-12s;
I have a 1984 LP-12 I bought new (in beautiful rosewood finish) which has corner braces, and I started selling LP-12s in early 1985 and all had corner braces. I don't know whether this was for export decks only. Also the braces weren't used to prevent warping but stop splitting of corner joints which could cause warping as well as looking unsightly.
John (and all),
I have a friend who has a Basis which I hear, as Jaybar wrote, "different" from an LP-12 not better. Keep in mind the Basis I heard costs more than my entire hi-fi!!
Ron The Mon
I sold my LP12 + ARO last December in favour of that Voyd The Valdi + Helius. Much more transparency and detail, while nothing to complain what misses compared to the LP12. I just upgraded the Voyd with a Zeta tonearm and like what it is doing.
regards,
Hartmut
I understand that the Audio Note TT3 with the reference upgrade (includes reference bearing and platter) is better value for the money and kills the Linn. Being that it is now produced by Audio Note UK, you could probably get a good buy on one.
You really should audition it.
Naim please note - As of yesterday, the infopop server is not displaying the messages immediately after they've been posted. It takes some minutes before this happens, so you're liable to be getting several duplicate posts.
Couldn't agree more
Definitely couldn't agree more
Also can anyone comment on the VPI product there seems to be alot for sale on Audiogon.
John
No - my 1985 LP12 came with corner braces.
--Jeremy
I have a VPI HW-19 mk. IV with SAMA (the $2k model) and SME IV arm. It sounds nice. I haven't compared it with any other tables, either at home or in a store, so I really can't comment on it comparatively. I got such a good price on it--it was less than a new P25, including the SME--that it was total no brainer. Sound might be a little on the dead side, but my understanding is that the Basis is even deader.
An Art Dudley review from Listener of the Aries (which is $2800 I think) is on their web page--www.vpiindustries.com.
--Eri
