AV2 Subwoofer connection
Posted by: Stuart M on 29 October 2007
I'll be using a NAP140 for centre and a REL via phono for subwoofer.
Is it possible to disable the sub out from the din socket so only 1/2 the NAP140 has to work. Or do I need to cut the wire in the sub wire in the SNAIC?
Posted on: 29 October 2007 by AV@naim
The sub output stage is hard wired to the din socket.
Technically it would probably be better to power down the channel not used, but this constitutes a non-standard modification which naim do not approve of...
Why not just leave the other channel disconnected?
Posted on: 29 October 2007 by Stuart M
Thanks for the quick response
Because a standard SNAIC comes with all pins connected, since the SNAIC is connected to the 140 and one 1/2 will be driving the centre channel.
Don't wan't to mod the 140 it looks like I'll have to cut a wire in the SNAIC or get one specially made unless there will be no problem with driving the unused NAP 140 channel but I believe the amp expects 3.5m of cable with a loudspeaker at the other end. Also the sub power swings (I guess) would reduce power available to the centre.
good point...
ideally a specially made cable. You need to speak to your dealer on this one though.
Posted on: 30 October 2007 by Don Atkinson
Why not buy a second centre speaker?
Don
Posted on: 30 October 2007 by Roy Donaldson
I don't think there's any problem with doing this, I've done it for a year or so, until I changed the 140 over to a 175.
Roy.
Posted on: 30 October 2007 by Stuart M
Because the AV2 SNAIC has a single centre and the sub. To have a second centre (I could use a spare SBL) I would still need a custom lead.
