Online Second-Hand CD Sites?
Posted by: Tim Danaher on 20 September 2002
Anyone know of any reputable ones? Or sites / organisations that search for deleted CDs (like the out-of-print book services)?
I'm trying to get a Lyrita CD of a 1982 recording of Lennox Berkeleys Sinfonietta Op. 34, recorded by Norman Del Mar. Cat. No. SRCD.111. Can't seem to find it anywhere. My vinyl copy's knacked.
Can anyone help?
Tim
______________________________
Os nid Campagnolo yw hi, dyw hi ddim yn werth ei marcho...
Posted on: 20 September 2002 by Former member
Second Spin
I've dealt with them on numerous occasions - they're good.
The only quibble I've had is that, on a couple of occasions I've ordered stuff that they've said they have in stock only for it not to be delivered cos they'd already sold it. They didn't charge me for them, but it was a bit of a disappointment.
Note that you can save considerably on postage if you opt for having only the CDs and paper bits sent rather than the jewel case as well.
Posted on: 20 September 2002 by colin thomas
Try http://www7.gemm.com, Jim Ashton recommended them to me and I found what I wanted. The item arrived about 10 days after I ordered. Searching under artist 'norman del mar' didn't bring up the item you're after though.
Colin
Posted on: 21 September 2002 by Tim Danaher
Nick and Colin. Nothing's turned up yet, frown but I'll keep my eyes peeled...
Tim
Posted on: 21 September 2002 by David Stewart
It might also be worthwhile to keep a lookout on E-Bay. At any one time they have upwards of 80,000 CDs and LPs on the site and rarities do turn up from time to time. You might have to pay a bit more for it though if its a popular piece.
