create a HT system
Posted by: Robbert on 04 May 2008
I have a super nait. When i like to make a HT setup will it be possible to do that with the super nait?
I was thinking of Super nait + AV2 + NAPV175
I already have a Bluray-player.
Then HDMI ( screen ) to my plasma screen. And digital out to the AV2.
I still want to use the super nait for music ( front speakers ) But when i look to a movie the front speakers must intergrade in the 5.1 system.
Will this be possible? Yes or not, please explain. Is there any schedule on the net?
Posted on: 04 May 2008 by james n
Av2 front output into Supernait AV input. Front speakers connected to Supernait for movie front and normal music.
Av2 Centre and rear connections to the 175.
I've got the same plans but with a Supernait and an n-Vi Smile
James
Posted on: 04 May 2008 by Robbert
OK,
And with what knob do i turn the volume up and down? The knob on the AV2?
I did some research work and i've seen in the manual a setup with a 112/150 stereo setup.
I guess it will work the same with the super nait.
The AV input on the SN should be unity gain so you use the volume control on the AV2 to set system volume when watching movies.
