Resolving Ground Loops? from Multiple Sources
Posted by: John on 28 December 2001
I was originally under the understanding from NANA that the P9 power supply will generate a lot of noise in my system and I should plug it in a separate socket. After a lot of playing around thinking initially I had a stand issue I discovered that to get the best out of my P9 I needed to plug the power supply in my main power bar and unplug my CDS1 from my 52. The results are significant! Is this normal? It seems strange to have a very expensive preamp and being faced with such an issue??? What are my options at resolving this?
Will a Stageline resolve this issue? If so can it be powered by my supercap similar to a prefix setup?
It would be nice to hear from someone at Naim on this as I am sure it effects a lot of people who own Rega decks. If you own a Rega TT try unplugging your other sources.
Any help is appreciated.
John
