Mains cable for the CDX
Posted by: Matt worlock on 10 October 2001
What are the sound improvements of using an alternative mains cable?
I have heard of the Russ Andrews range of Kimber cables, is it one of these Chris?
Cheers Mad Matt ![]()
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
It does everything else right as well.
However, the standard Naim lead is marginally better into a CD5 - better defined bass.
It's always a nice day for it, have a good one ![]()
Steve
Meanwhile I set about practicing some home surgery......scooped them up from the floor where they fell & managed to graft both my ears back on to no detrement to my hearing......Phew I was pleased! However by this time I had missed some important calls & my wife was asking why I was ignoring her.
Anyway last night I pressed me mute button again and WOW the sound had changed for the better. Treble frequecies at the extreme were'nt smeared S's & T's far smoother & in control than their original ear slicing onslaught. Everything sounding more natural with soundstage more focused, generally easier to listen to, to relax into.
Long may this continue!
PS With sound like this, Hutter will just have to wait....anyhow somthing closer to home would be better, Readings to far. I'd still like to check it out though..Cheers Andrew.
Bye for now Mad Matt.
Anyway, there might be a couple of other Hutter suppliers around the UK. Best phone Hutter, their website seems to ignore the low-key UK Hutter dealers.... if you feel the need now ![]()
Another thing to consider is that your interconnects aren't running in parallel and close proximity to each other. A fairly-large effect that will improve your involvement in the music.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Originally posted by Andrew Randle:
The problem is, when you power it down you will have to go through the whole thing again
Andrew,
not sure about the CDX (didn't own mine from new), but my CDS-II head unit benefited considerably from being powered down for a few hours about 4-6 weeks into the burn-in process.
Sounds bizarre, I know, but it can't do any harm to try it out.
cheers, Martin
Bob.
Not sure about the CDX (didn't own mine from new), but my CDS-II head unit benefited considerably from being powered down for a few hours about 4-6 weeks into the burn-in process
Not that I'm disagreeing, but how can you tell? I mean, how do you know that if you'd left you CDS-II powered up for those few hours that the same improvements wouldn't have been realised?
S'not exactly an A-B comparison, is it? ![]()
Originally posted by Duncan Fullerton:
Not that I'm disagreeing, but how can you tell? I mean, how do you know that if you'd left you CDS-II powered up for those few hours that the same improvements wouldn't have been realised?S'not exactly an A-B comparison, is it?
Well, no it isn't, but I was quite happy with the improvement. The sound really tightened up quite nicely, which I feel is a noticeable feature of the CDSII during early burn-in.
Of course, I can't say whether this will make any difference to the CDX.
cheers, Martin
Originally posted by Martin Payne:
Well, no it isn't, but I was quite happy with the improvement. The sound really tightened up quite nicely, which I feel is a noticeable feature of the CDSII during early burn-in. (**Edit: to clarify, the CDSII tightens up considerably during it's burn-in - the power-down seems to help this significantly**).Of course, I can't say whether this will make any difference to the CDX.
cheers, Martin
