Credo and 150 question
Posted by: cyu on 28 October 2003
hi all
I just recently acquired preowned Credo. I have never owned any Naim speakers until now. I noticed that there is this protruding metal piece from the main speaker drive, which I noticed quite common among Naim speakers.
I just found out that it is very lose and not tight fitted into the center of the main driver. I initially thought that it can be tightened by screwing it in or something, but can only be pushed into the center of the main driver. When I carefully removed the piece, I saw a plastice peg, which is inserted into the metal piece, and a trace of clear, thin layer of dry up glue of some sort on the surface of the metal piece.
I am hoping somone could tell me what it is and if it broken and how serious the problem.
Another question I have is that on the back of the Credo, someone installed crossdriver. I am not sure if the Crossover 1 or 2.
I noticed that layout markers (i.e. Red (+) and black (-))for the speaker cables on the back of the 150 power amp does not correspond to the cable layout on the crossover (black and red).
to illustrate what I trying to say
Nap 150: (left)Red Black blackRed(right)
Credo: (left)Red Black RedBlack(right)
As you can see by the illustration, left side correspond and "fit" to designated color. But for the right side, I have to bend / move the cables to have it fit correctly and may affect the sound. I apologize if I am not being clear with my question. I am hoping that this illustration would help get my question across.
Basically, is this normal arrangment and have to rearrange the speaker cables for the right half to have it fit correctly? Or Does the crossover comes in Left and right side and I have happen to have both left or both right?
any advice would ease my mind.
thank you all in advance.
