Stageline Question
Posted by: Justin on 15 June 2002
If you intend to run a stageline with a hicap, how do you get the signal from the hicap into your pre-amp. do you need a special cable (like 4pin to 5pin)? Does this badboy come with the stageline?
Judd
Judd
Posted on: 16 June 2002 by Martin Payne
Yes.
No, it doesn't.
Many users will be running them off NAIT5, 112 or 52, and these can parasitise the power from the preamp p/s.
This would be money wasted for those users.
cheers, Martin
Posted on: 17 June 2002 by Justin
It is no either/or situation for me. I have enough PSU's to go around. I'm just miffed that I have tp purchase yet another special cable to run the stageline from a dedicated PSU.
Rather than spend the 110 on the new cable, I'll probably replace the 240 degree four pin Din in teh hicap with a 180 degree 5 pin DIN. This way, i can use the standard Lavender interconnect between the hicap and the pre-amp.
Judd
Judd
Posted on: 18 June 2002 by Peter Stockwell
$110 for the stageline Snaic! They're £50 in the UK.
Peter
Peter
Posted on: 18 June 2002 by David Dever
DIN 4-5 should be either $75 or $90 in the States (can't remember; must add to retail list).
This is still cheaper than a Chord equivalent or the SNAIC-5 required to power the unit; this cable is standard with the more-expensive Prefix.
Posted on: 18 June 2002 by Justin
I was just guessing on the price. I figured it would be about what a snaic costs. I'm glad to see it is a bit less. Still, it is yet another special cable, which has (as far as I can tell) only one use (the very specialized application between the PSU and the pre-amp line level input--though I could be wrong about this).
Judd
Judd
