Nait/NAC** with tube amp
Posted by: Mike Cole on 06 March 2002
Mike
Originally posted by Mike Cole:
Has anybody out there tried using the preamp portion of a Nait 3 or any of preamps from Nait with a tube(valve) amp. How did it sound? Was the PRaT intact? Did it suck?
I used my 32.5/SNAPS as a pre-amp into a valve integrated amp for a while (as it didn't have a phono stage) and most of the character that came through was that of the valve amp. In fact overall I preferred the sound to that of the Naim power amps (including an active setup) although not with all types of music.
I wouldn't have any reservations about using a Naim pre with a valve power.
Steve
I worked at a Naim shop that also carried Conrad Johnson. To start out, we had the PV12 and the Premier 11a. We never got along with the PV12, it was clean but boring. We finally connected an 82/2Hicaps to the Premier 11, and it actually worked fairly well. The tube amp couldn't keep up with the preamp, but it was now at least trying to play the tune. The combination was simply terrific at imaging/soundstaging/etc, and "sounded" great.
I think tubes in general are just some people's cup of tea and not others. Anything that can make Husker Du's "Metal Circus" sound laid back is not for me, though.
Bob
I'd love the chance to try a nac 112 with this combo. I think it would be superb.
Markus
Then, home economics changed and the 250 was liquidated to provide tuition for an offspring. The Dyna equipment was borrowed, refurbished and put into the system where it sounded "good enough" for a couple of years.
Now I'm enjoying the dubious pleasures of owning vintage tube equipment. The Dyna went into the shop for a new power supply rectifier tube. Came back sounding better than ever, only to fail again. Now, after purchasing a new power supply board the electronics expert who has been doing the work has determined that one of my transformers is bad. $150 to replace that. At this point I don't want to throw more money at the dyna, I'd prefer to get back to Naim, something at least on the order of a 180.
You ask what I prefered about the Dyna, that's a tough one. The damn thing plays music just fine and I never felt I was really missing much, except the ability to crank the system up loud without strain.
Recently i've read in Listener about classic components and it turns out I've had two of them in my sytem--the 72 and the Dynaco. Not that it counts for anything. But I'd say these pieces of equipment have modest aspirations and their priorities are in line with my own. Does that make sense?
Markus
--Eric
