FLAC or WMA lossless?
Posted by: Fraser Hadden on 10 November 2009
I have done a search and can't find a concensus as to which is the better choice of storage medium for distributed audio. Perhaps it makes no odds.
Any preferences out there?
Fraser
Posted on: 10 November 2009 by Eloise
FLAC is generally better supported beyond Windows Media Player.
For that reason, unless you are wanting to use WMP as your player, I would go for FLAC on a PC.
Posted on: 11 November 2009 by {OdS}
Basically, it depends on what you need and how you plan to use your music files. Flac has the advantage of supporting tags, where Wave files are just, well, files with a name and nothing else. Using Wave files in a media player will result in displaying a long list of files with no further info regarding the composer, year, genre and so on. So much for sorting your music then. From a quality point of view, both should sound absolutely equally as not a single bit of information is lost when storing (and loading) the Flac file. Both formats are very well handled in a multidude of systems, too, not only in Windows. Still, Wave is a straightforward way of storing audio: bit-per-bit copy of your CDs on the hard drive, end of the story. No need to compress when storing, no need to rebuild when listening. I like this too Winker Hope that helps.
Posted on: 11 November 2009 by Fraser Hadden
{OdS},
Er...
In the nicest way, it doesn't help. I didn't ask about Wave, I asked about WMA lossless vs FLAC.
Eloise,
Thanks for your input.
Thus far: FLAC 1 WMA Lossless 0
Fraser
Posted on: 11 November 2009 by likesmusic
Three big payoffs with FLAC are a) it is lossless, b) tracks can be tagged however you want, c) you can save a lot of storage space. With products like dbpoweramp FLAC files can be converted (or ripped simultaneously) to other formats in any case, so you are not committed. Saving storage space is arguably not that big a deal as mass storage is so cheap, but it still costs money that could otherwise be spent on music. There is quite a good discussion about rippping strategies on the computeraudiophile website.
Posted on: 11 November 2009 by Peter Dinh
FLAC, no hesitation at all if you are a PC user.
Posted on: 11 November 2009 by spacey
wma doesnt hold meta data.
Posted on: 11 November 2009 by church warden
I don't use them anymore, but I believe WMA and WMA lossless do support metadata.
However, I would agree with Eloise's recommendation of FLAC. Furthermore, there are more possibilities for playing FLAC on a Mac (should that be relevant now or in the future) with Play, Songbird and even Fluke/i-tunes coming to mind. I could be out of date, but I believe the only current route for WMA on a Mac is Flip4Mac with Quick Time.
Posted on: 13 November 2009 by {OdS}
{OdS},
Er...
Fraser: WMA files are actually Wave files renamed in Windows Media Audio files. They are plain Wave files, though and you can play them on any platform that can play back Wave files.
Posted on: 13 November 2009 by Eloise
{OdS},
Er...
{OdS} ... I don't think you're right there ... to Quote from Wikipedia (not always the most accurate I know ...
From Wikipedia, the free encyclopedia
Windows Media Audio 9 Lossless is a lossless audio codec by Microsoft, released in early 2003.
It compresses an audio CD to a range of 206 to 411MB, at bit rates of 470 to 940 kbit/s. The result is a bit-for-bit duplicate of the original audio file; in other words, the audio quality on the CD will be the same as the file when played back. WMA Lossless uses the same .WMA file extension as other Windows Media Audio formats. It supports 6 discrete channels and up to 24-bit/96kHz lossless audio.
Which is pretty much was I understood too...
Eloise
Posted on: 14 November 2009 by {OdS}
So much for me then! Flac should definitely be the default choice then, since it does what WMA does but not only in Windows systems.
Posted on: 17 November 2009 by js
Carefull here as neither WMP nor Itunes plays FLAC without help. Mac has limited aftermarket player support so I would just use ALAC for APPLE computing. It's an interesting situation as the most commonly used media players don't support the audio geeks favorite Lossless format. I know that you can get FLAC playback in WMP with a DCBassSouce download and there may be an app somewhere for Itunes. If you're a PC user, there's plaenty of FLAC friendly players out there. Flac is the least universal because most computer owners don't have an installed program to play it. It is however the least proprietary and those that care, can find a way to use it.
Posted on: 21 November 2009 by Fraser Hadden
Thanks to all contributors.
FLAC it is then!
Fraser
