Russ Andrews 'Naim Interconnects'
Posted by: mark dunsford on 10 October 2001
I see that Russ Andrews has branched out into DIN to DIN interconnects, specifically aimed at Naim systems.
I have used the hybrid 'Silver Streak' between my Kairn and 250 (XLR to Phonos) with impressive results - has anyone tried the DIN -DIN connectors?
Posted on: 12 October 2001 by Matt worlock
Oh yes sir .......I,d give umm a try...hey when i do I'll let you know what I thought.
Cheers Matt ( madboy)
Posted on: 13 October 2001 by Andrew L. Weekes
I'm not sure his scheme is a good idea.
The connection scheme he shows, bypasses the signal routing via PSU's, a specific part of the Naim design.
He is, in effect, destroying the star-earthing inherent to the Naim pre / psu / power design.
It is very likely to sound different, but as for better, I doubt it.
Andy.
