Mounting a Prefix in a LP12
Posted by: John on 26 November 2002
The instructions I have for mounting a prefix in a LP12 state:
"Attach prefix to the underside of the front right-hand corner brace of the turntable plinth, using the three wood screws provided."
My prefix included 3 (1cm) small screws, 3 (2 cm) larger screws and 3 plastic tubes that are 1cm long. My arm is an ARO and my guess is the platic tubes are adaptors for different arms as some might hang lower but the instructions don't talk about it. Should I be using the long screws and plastic tubes with my ARO? I assume the plastic tubes go between the prefix and the corner brace.
John
John
