Supercap Connections
Posted by: Naheed on 31 August 2002
I'm using a 82/Supercap with two SNAICs. Question i have is, should there be a burndy link plug fitted, the manual says no, but seems strange as the Snaxo i use requires a link plug if the burndy connection isn't used ...
naheed
active Phase 5 SBLs is the only way...
naheed
