AV2 and monoamps
Posted by: NigeP on 11 December 2005
Showing my ignorance here but can you drive monoamps from the AV2 without going through another pre-amp.
looking to reduce box count by driving my monoamps+NAP175 from AV2 and eliminating my preamp altogether
also has anyone used a stageline into AV2?
confused
Nigel
Posted on: 11 December 2005 by Trevor
This is as I understand it what Naim do when the pre-amp is switched to unity gain. The signal goes straight to the power amp. OK it goes via the pre-amp cabling wise but the pre-amp does nothing to the signal.
Posted on: 11 December 2005 by NigeP
Thanks for the reply Trevor, but if you want to just use the AV2 as a preamp can you drive monoamps (135s etc) directly from AV2 or do you need to keep the preamp
Confused
Posted on: 11 December 2005 by David Dever
You need to order a Y-cable (DIN-4 to 2 XLR-3) from your dealer.
Posted on: 12 December 2005 by Trevor
I see no reason why with the correct cable to connect the AV2 output to the inputs of your power amps there should be any problems.
# Point of caution #
Set the AV2 front volume output in the setup menu and the overall volume control on the AV2 to minimum prior to switching on the power amps and adjust upwards as required to avoid any loud suprises.
Posted on: 04 January 2006 by Dandy
I have such a cable that went from my AV2 to two 135s. I think it's called an NA-52
Posted on: 04 January 2006 by NigeP
great many thanks Dandy and David
