My system sounds great or Am I crazy (long?)
Posted by: KENB on 19 October 2003
Well I just had to say it because it does, despite it's humble stature, sound so good I am rarely tempted to buy the latest and greatest at the shop. Although a system with Verity speekers did excite me recently.
My sound is detailed and energetic but not harsh. And timing is great something you only understand when you finally hear it, at least for us non musician types. It seems to be very good a tonal balance and nuance. It really amazes me how much individual little instrumental touches it picks up with the utmost clarity while it is still very easy to listen to.
My gear is 62/140/NACA5 Bi-Wire to Meadowlark Kestrel Hotrods. Sources are Technics vintage tuner, Rega planet cd with MSB Link DAC 3. Finally rega 3 with expressimo heavy weight and cardas wire with Benz MC20 High output cartridge on a target wall rack and a parasound phono. Also a dedicated Line from the fuse box (Canadian eh!).
Why all of a sudden the urge to post? Because I have just won a HiCap on E-Bay and am still wondering can it really be that good? I found that the dedicated line and the DAC were the most musical and enjoyable improvements if not necessarily the largest changes (62/140 upgrade from NAIT2 was big). These changes did not so much add to the music as fix problems that were annoying and thus allowed the sound to really shine and be enjoyed.
So will I really find that the HICAP can improve on this? It seems to go without saying it will be great, has anyone ever not liked the HICAP? Or am I giving in to the knowledge that there is always improvements and sometime you really get a big one?
Some here have advised that my soures are needing work first. I like my CD set up quite a bit but maybe a cartridge would have been better.
My philosophy is that I don't want anything in the way of a source upgrade. So I want everything to, at least within my budget, be ready to play when those really important decisions happen. I don't want to second guess if a cartridge is not performing or is my sistem too humble to make it work.
just having fun,
Ken
Posted on: 19 October 2003 by Rico
congratulations, Ken.
one thing you may like to consider. Ditch the Bi-wire. Not a good idea with your Naim amp.
Rico - SM/Mullet Audio
PS - plug in the hicap, then post. You'll wonder how you lasted without it.
Posted on: 19 October 2003 by KENB
Unknowingly before finding this site, I have been using Bi-Wire for years with NAIM. No problems. I have experimented a bit with jumpers but at this point I prefer the bi-wire. It's a subtule difference but it feels a bit more natural and clearer with bi-wire. I wonder if I might be able to play louder with single wire but I don't get to play loud very often.
Ken
Posted on: 19 October 2003 by Phil Barry
Interesting conundrum. The hicap will definitely improve the output from the preamp to a considerable extent - but will it upset the applecart and set you off on an unexected, undesired upgrade path?
The hicap will, if working prioperly with other properly working Naim stuff, improve highs amd lows, increase musical coherence, and reduce compression and congestion.
Regards.
Phil
Well if that's what happens I should be very happy indeed. Sounds like more of a good thing. Certainly the HICAP has to be the most recommended device I have ever read about.
I really won't be able to afford another significant upgrade at least on the amp side. I plan on keeping these for a while.
Ken
Posted on: 19 October 2003 by Geofiz
Ken,
The HiCap will be a big upgrade. Everything you like should increase since the amp will essentially be unfettered as it will no longer have to supply power to your 62.
I too had biwired my Kefs using a solo 250 and then 135s for years. Even have biamped using the 135s for the lows and the 250 for the highs. Currently running just the 135s (no biwire) as moving to a 52 (from a 32.5/Hicap) just allowed the 135s to open up and sing.
Carefull, 'cause adding the Hicap may make you quest for more.
Have fun.
Posted on: 20 October 2003 by Nime
Ken,
I am very much afraid that you are going to find the need to upgrade all through your system the moment the HiCap hits the fan. So I'm going to have to insist you post it to me immediately to save all the inevitable torment & distress it is bound to cause. You know deep down that this is the only solution that makes any real sense. Big Grin
Nime
Everyone has the right to be wrong.
Posted on: 20 October 2003 by KENB
I suppose I will start with the Audio technica soundberger as a backup in my bedroom?? Big Grin
Posted on: 20 October 2003 by MichaelC
Ken
Enjoy the Hi-Cap - let it bed in and rediscover your music. Mind you I have a sneaking feeling that more will follow...
All the best
Mike
Posted on: 20 October 2003 by Steve Toy
Get rid of the jumpers and replace them with bits of Naca5 and you'll then know why you needed to biwire in the first place. Jumpers suck, and thus the mythical benefits of biwiring are created.
Steve.
When I said jumpers I mean NACA5 or Ecosse short bits bare wire connection. Should I do some soldering or put on Banana's or spades?
Steve.
Posted on: 21 October 2003 by Craig B
Ken,
Try using the search skate board for details on the F-connection method.
In summary, it is two pairs of Naim bananas, one pair soldered onto the end of the cable as per usual, the other pair soldered on at the exact distance back from the end as your two pairs of speaker sockets are apart from each other centre to centre.
You can easily line up where the second set of bananas should be soldered onto the cable by first fitting the end set and then plugging them in such that you can accurately mark the cable positions for the purposes of stripping a short length of insulation to allow fitment of the second pair of bananas further down.
Finally, following the actual stripping of the insulation (try a C-section cut and then peel away the sheath), reinsert the end set of bananas into the upper set of sockets on the speakers such that you can then accurately mark the plug positions for the lower set of sockets and solder them on (post removing them from the speaker sockets of course).
A variation of this method can also be employed should your speaker socket pairs be positioned side by side rather than one above the other.
BTW, say hello to Gary at Better Music from his friends in London, ON.
Craig
Posted on: 21 October 2003 by KENB
Originally posted by Craig Best:
Ken,
Craig
Yep mine are dide by side. BTW Gary has changed his operation and no longer has the store front. you might want to contact him fromhis web site to see what he is doing. The phone number is still the same also http://www.vaxxine.com/betmusic/home.html
Thanks,
Ken
