Flatcap 2 advice needed
Posted by: Freckles on 21 October 2003
Hi
I've just bought a CD5 and am hopeing to add a flatcap 2 in the next few weeks. My question is do the necessary leads come with the flatcap 2 so I can connect it to the CD5 or do I have to purchase the lead separately? If I have to buy the lead separately how much does it cost in UK £. I also a little confused with all this grey snaic and black snaic buisness. Is the black snaic the version to get or is this only for higher end Naim equipment such as a Hicap? If there are two versions will it make a difference to what one I buy or the amount they cost? Thanks very much in advance.
