Question for a LP12 and Klimax DS owner
Posted by: T38.45 on 30 June 2010
Hi there,
just a simple question...can a Klimax DS reach the emotional level as it does with LP12?
Ralf
Ralf
Posted on: 30 June 2010 by gone
<NNC - No Naim Content>
Probably best asked in another place
Posted on: 30 June 2010 by Klout10
The Linn site has a forum, better changes over there...
Michel
Michel
Posted on: 30 June 2010 by T38.45
aargh ...right....sorry, my mistake!
Posted on: 30 June 2010 by Guido Fawkes
it would have to sound better than the Accurate - I'd sooner listen to a CD5i than that any day of the week.quote:can a Klimax DS
Posted on: 30 June 2010 by Former member
Nothing brings the emotional level you get from playing a record on a lp12.
I will now duck for the incoming.
Posted on: 30 June 2010 by james n
quote:Nothing brings the emotional level you get from playing a record on a lp12
I've started rustling newspaper whilst listening - it gives me that same distracting surface noise effect i (dont) miss from vinyl
Posted on: 30 June 2010 by rich2513
I heard an akurate DS albeit quite briefly. It sounded very hard to me. But then part of that is the Linn sound, very strong, strident and punchy. Part of it may have been the system matching as well, although it was a naim pre + power.
The salesman was kind enough to point out that the Klimax was a significant step up and was 'starting to get there'. A lot of money though. I am keener to explore the various naim routes and have consistently preferred the naim sound over the linn philosophy.
