PMC FB1s; Good Reviews; Good Speakers?
Posted by: Alex S. on 17 October 2001
Alex
Its Alvin Gold, and I don't mind at all how you spell it. I enjoy his colourful prose but would not dream of believing a word he says.
I'm auditioning them tomorrow I hope. Met thought they might be good for me - he knows I want fast, tuneful bass.
I also want bags of round earth stuff I'm afraid so the SBLs are not really my thing. I'm better off with speakers well into the room, although I liked the Allaes (with CDS2/52/500 - I may have liked anything).
Alex
Stephen
IIRC, PMC used to use Naim as their "preferred" amps before they got into bed with Bryston. At a Penta show ages ago, I heard a pair of their LB1s perform superbly with Roksan CDP, 52/SC(?)/135s. This was a very small room though, and apparently the LB1s can shut down 135s quite quickly (not that it happened!). In that context though, the LB1s seemed vastly better than the FB1s did more recently. I was reminded of the LB1 experience when hearing the Allaes at Bristol this year (also with 52/SC/135s). Something was very "right". Front end/amps? Possibly.
Best;
Mark
(an imperfect
forum environment is
better than none)
You have heard the allea & not told me what you thought .....shame on you!
Question : Do you think my 180 will drive them ok? Or am I better to spend money of diff speakers.... poss credo??
Cheers Mad boy Matt ![]()
Hey.....You also looking for speakers! what are you using in the rest of your set up.
From Mad boy Matt (I work in Bristol)
Bub is correct Alex. These are good speakers placed well out from the back wall in a large room driven by a 250. Could be worth a listen.
Bri
Later,
Alex
b. P.S. Fake, I believe, difficult to tell from this range: pffffsssspt is my riposte.
Alex
Deep, solid bass; accurate pitch and tonal balance.
Against:
Slow as f*ck.
Verdict:
No.
It's always a nice day for it, have a good one ![]()
Steve
Maybe the guy who swapped his SBLs for the PMC was on to something. Mind you, SBL always been horribly overated
Redeye
FB1s really mess up the timing of music in general, IMHO.I'm more concerned with leading edges of guitar and piano strings, as well as those of light percusive instruments, that FB1s just can't manage as cleanly as the likes of Naos, or even Ruark CL20s - which are the same price as the FB1s, for example.
I agree with you on SBLs, though. They just seem sooo difficult to set up, IMHO, and they don't do deep bass at all.
Have a good one! ![]()
Steve.
It's good to get back to normal. ![]()
Don't believe half the stuff you've heard. PMC FB1s are NOT slow, do NOT have a soggy bottom end and can certainly carry a tune. Well worth considering if like me you find the whole Naim speaker thing slightly funny. If you are a musician or attend loads of live music you will 'get' these speakers immediately. They do nowt wrong
Redeye
