NAC102/NAP180 or NAC112/NAP150
Posted by: Robby on 18 February 2002
A secondhand (about 2.5 years old) NAC102/NAP180 or a new NAC112/NAP150.
Any opinions?
Also if i bought second hand when would I need to service the NAC102/Nap180?
Originally posted by Robby:
What would be a better buy:A secondhand (about 2.5 years old) NAC102/NAP180 or a new NAC112/NAP150.
Any opinions?
Bo brainer - the NAC102/NAP180.
A 2.5 year old pre and power won't need serviced for several years.
Steve
I borrowed a 102/180 a while back and found my Cambridge CD player too harsh to listen to after a short time. It sounds much nicer through the 112/150.
My LP12 sounded better through the 102/180 though.
Steve B
Going for either 112/150/flatcap or 102/PSC/180 - both with CDX/Allaes there was no doubt that 102/PSC/180 brought out a harshness that I rapidly found unacceptable. To my ears the whole set up was better 112/150/flatcap.
Max
The 112/150 may be more listenable, and therefore a better match to what a listener may want, but I wouldn't call it unqualifiedly 'better'.
Phil
from 'I'd choose more listenable myself', Illinois, USA
But the TT sounds fabulous through this combo. I have a flatcap connected as well though.
It really is a good combination and I love it.
102/180 without any hesitation.
But like the other folks have mentioned, you need balance. The right choice for you will depend on whatever else you have in your system, what your long-term goals are (if you have any
) and what your listening environment is like.
If it helps I have a bare CDX, P25 and Credos and no harshness. In fact listening last night to Ryan Adams - Gold I had just the opposite.
You don't need a CDS2 and 52 to get a chill down your back
Jay
I play my CDX through an 82/Hicap ATC active system and it isn't harsh. I have heard a CDX through a 102/180 and that wasn't harsh so the CDX may not be the problem. Now, if you want harsh try an LP12 with a K9
Wrong settup -> Harsh
- GregB
Insert Witty Signature Line Here
