HiDef Stereo
Posted by: Mr Underhill on 11 November 2007
18 months ago I posted a discussion on how to burn a DVD-A:
http://forums.naim-audio.com/eve/forums/a/tpc/f/7801938...942916407#8942916407
That was all very well and good ....BUT, it means I can't give the discs to anyone without a DVDA player.
Using the M-Audio MicroTrack 9624 the high resolution soundtrack I can record is 96 KHz 24Bit, which is the max resolution usable on a standard DVD.
The MicroTrack 9624 is flexible enough for me to record live and also connect to my pre-amp, and record from tuner/turntable etc.
I am not interested in authoring multi-channel recordings, and would prefer to use my Benchmark DAC1 for decoding duties - so DVDA is not a must-have.
My immediate need is to create a disc that I can give to marriage candidates to allow them to pick what music they would like, and control their expectations of what our choir sounds like! By producing a DVD it saves me having to produce a lo-def track to burn to CD.
Sooooo,
I looked for some commercial offerings - but they were all (both) a few years old and didn't appear to be being supported.
Looking on:
http://www.meridianunplugged.com/ubbthreads//ubbthreads.php/ubb/cfrma
I found a reference Lplex:
http://sourceforge.net/projects/audioplex/
This is a small windows command line application.
You place the files you want to burn to DVD in a directory and then drag and drop them onto the .exe (or batch file) and it produces an ISO file for you.
Works a treat.
M
Posted on: 14 November 2007 by {OdS}
thank you for the link to audioplex Mr Underhill, this definitely looks like it's worth a try!
Posted on: 14 November 2007 by Mr Underhill
Hi OdS,
Pleasure.
I was glad to find it!
M
