Great Barbecue Recipe - Beer Can Chicken
Posted by: rodwsmith on 07 June 2010
I mentioned this famed Caribbean cooking "method" on another forum, and having spent ages typing it up, I thought I might post it here too - it tastes great and will make your barbecue the talk of your friends...
Beer-Can Chicken
As using whole chicken(s) you need to make the marinade very strong/hot to get it to permeate at all. The further in advance the better obviously.
After all the cooking this does not end up as hot as it sounds, but you can tone down the heat if there are wimpy people and or children...
Jerk Marinade (1 chicken's worth, say 4 people)
4 - 6 Scotch bonnet or habanero peppers, seeded and chopped
125ml Dark Rum
Juice and zest of 4 limes
75ml white vinegar
125ml Corn (or olive) oil
This is a basic jerk flavour, add (to taste):
1 tablespoon crushed black peppercorns
2 tablespoons salt
1/2 teaspoon ground cinnamon
3/4 teaspoon grated nutmeg
1/4 teaspoon ground cloves
1 1/2 teaspoons ground allspice
4 teaspoons chopped garlic (or paste)
1 tablespoon chopped ginger
about 8 - 10 spring onions, finely chopped
50g muscovado (preferably) or dark brown sugar
Mix and blend all this, and then get it onto and into the chicken. Rubbing it in by hand is best (wear gloves!) or alternatively you can stick it, and the chicken, in a plastic bag, seal and give it a good shake. Either way, let the marinade and the chicken mingle romantically in the fridge, under plastic or cling-film for as long as you can, preferably overnight.
Get the barbecue well hot.
Open a can of beer (per chicken). Presidente might be best, but Red Stripe or Carib, or obviously any bland, slightly-too-sweetish lager will do.
I can only express the next part as 'impale' the chicken onto the beer can, as far as it will go. If you can cook it upright, then great, if not then you will need to coordinate the position of the ringpull hole and the angle of the chicken. Cooking two at once helps positioning-wise.
Onto a tray, on the barbecue, cover.
The beer boils and evaporates and the moisture has nowhere to go but into the meat.
Subject to the usual juices running clear etc, about an hour should do the trick, and it does not need supervision, although a baste with the juice and/or a bit more oil will help make the skin even crispier.
Serve with salad, and maybe rice'n'peas (black-eyed). A lot more work than sausages and burgers but worth it, and a talking point.
Before
After
Rod
Posted on: 07 June 2010 by tonym
That sounds great Rod. I presume you cook it on a kettle-type barby with the lid on so it cooks a fairly evenly?
Posted on: 07 June 2010 by Occean
I've made this a few times, it's fantastic. I use either my Bradley electric smoker or weber hot smoker works pretty well on a kettle drum if you can get your heat right or in the oven
don't forget your wood chips!
Posted on: 07 June 2010 by u5227470736789439
New Year's Eve about four years ago I had this recipe - more or less - cooked slowly in the oven.
The difference was that the can was replaced by a bottle of Lech beer, which might be a bit risky on a BBQ. Not a problem in an oven though.
The meat was very succulent and yet the fat had found its way into the pan, which is probably a quite healthy way of oven-baking. The chicken had been very well maronated beforehand.
Why is it usual to call oven-baking, "roasting?"
Four of us kept going till there was none left. This was cooked by a Polish friend of mine ...
ATB from George
Posted on: 07 June 2010 by Mike-B
I picked up & used this recipe (very similar) when I lived in South Africa
My braai skills were in great demand - so much more with a good supply of company supplied cans
The big debate - greater even than Sharks vs Cheetahs - was the pros & cons on Castel vs Windhoek as the beer can option
To fine tune:
Each can needs to have a mouthful glugged out before insertion, too full & the can boils over
Best done "indirect" that is the fire to both sides or all around & the chicken in the centre over a fat/liquid catch tray
Heat needs to be high to start, but quickly reduced to slow & low until the skin has turned a nutty brown
Posted on: 07 June 2010 by mudwolf
sounds great, I'm just worried about 4-6 habanero chilis and I live in LA.
One friend used to have beer parties and cleaning up the next day would make a stew and start with emptying all the left over beer into a big pot as basis for the stew. I don't know what else he added but he said it was always great.
Posted on: 08 June 2010 by irwan shah
Rod:
If you are making this for the next Naim summer BBQ, I will be seriously tempted to fly to the UK for what looks like a totally scrumptious bird! Big Grin
Posted on: 08 June 2010 by Eloise
If emptying individual cans ... how do you avoid the dog-ends??
And with the chicken ... Just a warning ... if you are thinking of doing this with any kind of bitter - make sure you don't get a can with any form of draught flow device!! :-)
Eloise
