Static Noise from my new Naim Nait 5
Posted by: AlanK on 01 April 2003
I have recently bought a Naim Nait 5. After warming up for about 2 days, I notice some static and popping noise from my speakers when I adjust the volume or the balance (either from the remote or from the front control). If I switch off the unit, and then switch it back on, the problem is gone. But after leaving the unit on for another day or so, the problem returns! Please help!
Posted on: 02 April 2003 by James J
Hello AlanK, and welcome to the forum.
I wouldn't worry about it my nait 5 does very similar things.
Although mine never makes any pops when i change the volume and i've never altered the balance, it does seem to pick up electrical 'rubbish'.
For example when my boiler turns on i get a pop from the speakers, also when i turn off the cheap lamp i've got in the same room it does the same.
Might be worth getting your dealer to look at it.
Is it new?
As for a static 'hiss' from your speakers this is also perfectly normal, but shouldn't be too loud.
I think i would be right in saying that this is the case with all of naims amps.
James.
Posted on: 02 April 2003 by Nick Case
Sounds like you have electrically dirty equipment on your ring main.
The best cure would be a dedicated mains spur which would isolate your gear from boilers, fridges, dishwashers, lamps and other nasty electrically noisy appliances.
One of the best 'upgrades' around and one straight from your Naim manual itself.
Nick
