Switching off Lights for an hour
Posted by: Diccus62 on 28 March 2009
Posted on: 28 March 2009 by davidge
Yes - and listen to some music in the dark if I can find where to put the CD...
Posted on: 28 March 2009 by u14378503097469928
<Wonders if Las Vegas will go dark> wry smile.
Posted on: 28 March 2009 by winkyincanada
A better question is to ask is "Are you planning to do anything significant about climate change?". There are very few meaningful options available to most of us.
Posted on: 28 March 2009 by Bob McC
will they put the lights out in Canary Wharf?
I bet they don't.
I bet they don't.
Posted on: 28 March 2009 by Diccus62
I fell asleep (with the lights out)
Posted on: 29 March 2009 by FlyMe
I hope you limted youur carbon dioxide output whilst you were asleep.
Posted on: 29 March 2009 by ianmacd
Yes, we've already done it!
No kids in our lives.
Ian
Posted on: 29 March 2009 by winkyincanada
Me too. Kids in my life, but they're not mine. My DNA stops here.
Posted on: 29 March 2009 by Officer DBL
quote:Originally posted by ianmacd:quote:Originally posted by winkyincanada:
Ian
None here either!
Posted on: 29 March 2009 by Diccus62
I've got enough for all of you
Is this a Naim thing?
No kids here either!
Posted on: 30 March 2009 by Mick P
Chaps
Switching off lights is a waste of time, most bulbs are low wattage.
If you really want to lower your electricity consumption, swith off the air conditioning.
Use fans instead as they use a fraction of the power.
Mick
Mick
Posted on: 30 March 2009 by Bruce Woodhouse
Can anyone tell me if this is true?
I had the impression that with new eco bulbs it can be more efficient to leave them on than switch them repeatedly on and off as this causes a surge of power to 'start' them each time.
Did I get hold of a modern myth?
Bruce
PS Childless here too. Perhaps those green lights on the front of Naim kit make you sterile. I think we should be told!
Bruce
Posted on: 30 March 2009 by Diccus62
A green light on the front of my Naim kit.................... I hadn't noticed.............................. oh yes, isn't it pretty
That could be deemed as sexual harassment
quote:Originally posted by Diccus62:quote:Originally posted by Bruce Woodhouse:
That could be deemed as sexual harassment![]()
"Big breaths now"
"Yeth, and I'm only thirteen"
Bruce
Posted on: 31 March 2009 by JohanR
quote:I had the impression that with new eco bulbs it can be more efficient to leave them on than switch them repeatedly on and off as this causes a surge of power to 'start' them each time.
It's a myth in that sense. It's not in the sense that it lowers the life of the bulb, new ones has to be manufactured which uses energy and they has to be transported which uses energy, etc, etc. There is of course a breakpoint where leaving it on will use up more total energy.
BUT! Remember, the heat from the bulb (all the energy put into the bulb will eventually be turned into heat) will help to warm your house, you will use less energy in the heating system to reach the same indoor temperature. Not much of a waste there.
And a final tip to you Britts on how to save on the heating bill. Better insulation of the house. Cheapest in the long run.
JohanR
Posted on: 01 April 2009 by Guinnless
quote:Originally posted by Mick Parry:
Chaps
Mick
Not many UK homes have air-conditioning so switching it off could be difficult.
Steve
