VHS to DVD
Posted by: Analogue Rules OK on 14 March 2010
Will copy write protected pre recorded VHS tapes
be able to be recorded onto DVD?
Chris N
Posted on: 14 March 2010 by tonym
Simple answer - yes. VHS tapes can be protected from being over-written but not from being copied.
Posted on: 14 March 2010 by TomK
Sorry but perhaps not quite so simple. Pre-recorded VHS tapes were often protected by Macrovision which meant they couldn't easily be copied. You'll need to make sure that the process you intend to use can cope with this possibility or you'll get copies which flash, buzz, roll, and are generally unwatchable.
Posted on: 14 March 2010 by Guido Fawkes
I've copied protected VHS to DVD by recording through my TV - my DVD recorder will record what ever the TV is showing through the AV2 SCART socket - seems to just work - doesn't work through HDMI though.
Posted on: 15 March 2010 by Analogue Rules OK
Thanks for your helpful advice.
Chris N
