Naim iSupply?
Posted by: Integrative Service on 01 April 2005
What is included with the Naim iSupply for the Apple iPod? Does it come with a Mini-to-DIN interconnect? If not, does Naim make a Mini-to-DIN? Thanks for you time!
Posted on: 02 April 2005 by Richard AV
It comes with a DIN to Firewire adaptor.
Posted on: 02 April 2005 by David Dever
The iSupply provides 24VDC power only via a DIN-5 240° plug, which is then adapted to a 6-pin (female) FireWire socket plug. An appropriate cable (6-pin to 6-pin FireWire for gen 1 and gen 2 iPods, or 6-pin FireWire to dock connector for gen 3 and later units) then plugs into the FireWire socket plug. You will still need an appropriate interconnect to connect the unit to your system
NaimUSA offers a Chord Chrysalis X51JC-N (1m) or X51JC-L (2m) 1/8" stereo mini-plug to DIN-5 180° interconnect. Please phone us for pricing (website not yet updated) or contact your dealer.
David Dever
David Dever
Posted on: 02 April 2005 by Ron Toolsie
'us'? Are you back with NANA Dave?
Ron
About given up on the idea of powering the iPod via the 552 head units Prefix feed.
quote:Please phone us for pricing
Ron
Posted on: 03 April 2005 by Aric
Does the iPod always run off it's battery charge, or is that bypassed when it's plugged into an external power supply?
Posted on: 03 April 2005 by David Dever
The iSupply will, in fact, charge the unit while in use. It may also be used with the iPod dock, which some have found to be better sonically than the headphone output on top.
dD
(Yes, Ron, back officially since 31 Jan.)
dD
Posted on: 03 April 2005 by dave simpson
Good to see you back dave!
Posted on: 04 April 2005 by Ron Toolsie
The iPod is about the ultimate convenience-level music server. The iSupply takes its performance (plugged into a top flight system) from marginal to quite acceptable. Most of the listening I did yesterday-admittedly background while I was in an adjacent loft area was with the iPod/iSupply.
In the last week I have become more accustomed to the sonic signature of the iPod with and without the iSupply (as well as with the noise generating 552power feed/SPS power supply)and consider the iSupply virtually essential when attempting to recreate any of the gestalt in a musical performance.
If you ever plug an iPod into your main system you NEED an iSupply. And the Chord miniplug/DIN5 connector is just fine-albeit at a cost of more than 50% of the iSupply!
Ron
Ron
Posted on: 04 April 2005 by Bruce Woodhouse
How much is the iSupply and the Chord cable?
I might use this in my 'office system'.
Bruce
Bruce
Posted on: 04 April 2005 by Aric
Could someone please explain how devices that use a battery, direct current, benefit from an external power supply?
I just don't understand how a device that runs off batteries can be bettered via any sort of a power supply?
I realize this question is probably better suited in the audio room...sorry.
Aric
Aric
Posted on: 05 April 2005 by Webke
I am planning on buyin a ipog mini next week, it will mostly be used for when I go to the gym etc (ill buy an armband thing too) is the mini compatible with the isupply?
