Nait 5 / Nap 175 functionality question.
Posted by: Mr_Sukebe on 20 March 2003
Chaps,
Can someone please tell me if I can use a Nait 5 / Nap 175 in the following two ways:
In Stereo - CD player into the Nait 5 for pre-amp work. Pre-out from nait to Nap 175 to power front stereo pair of speakers
(I assume this is fairly straightforward)
In AV - DVD player to my AV amp (Marantz 4300).
Front stereo speaker pre-outs from AV amp via pre-amp section on Nait 5, then onto Nap 175 to power front stereo speakers
Front centre channel pre-out from AV amp directly to centre channel on Nap 175.
Rear stereo pre-outs from AV amp to Nait 5 power amp section, then onto rear stereo speakers.
I know that this is not exactly the way a 175 was envisioned to be used, but it would mean 3 matching amps for the front channels, whilst my nait power amp could power the rears. Would certainly save me a huge amount of cash when the other option is to add a Nap 150 etc etc.
Posted on: 20 March 2003 by Mr_Sukebe
Hey, this is a bit scary, 42 views but no one knows the answer.
Surely one of the moderators must know?
Posted on: 20 March 2003 by Richard Dane
It should be possible in theory. One point to remember though is that when using the Nait 5 as a pre-amp you need to have a separate power supply such as a Flatcap or Hi-Cap or else use a power amp which can supply the juice. Unfortunately the NAPV175 cannot supply power to a pre-amp so a separate power supply would be needed. Otherwise it should work - your dealer should be able to supply the correct RCA-DIN interconnects - but I can't predict compatibility or possible earth loops.
Richard
Thanks for that, useful info.
Could the Nap150 supply power to a Nait 5 used as a pre-amp?
Posted on: 20 March 2003 by Steve B
The Nait already has its own built in supply. Why can't this be used?
Steve B
Mr Sukebe,
A NAP 150 could supply power to the Nait 5 when the Nait is used as a pre-amp.
Steve B,
when you split the Nait 5 into separate pre and power sections, the pre-amp loses it's power supply. Normally this would then be supplied either by the partnering power amplifier or a separate power supply unit like a Flatcap or Hi-Cap. In the case outlined by Mr Sukebe the power amp section of the Nait 5 will be used with the pre-amp section of the AV controller and so it would be very difficult (but perhaps not entirely impossible if you're very handy with a soldering iron to make up a custome SNAIC) to get it to supply power to the pre-amp section of the Nait. As I've said earlier the earthing implications for such an arrangement may make this impractical.
Richard
