Where can I buy Allen headed Cartridge Bolts ?
Posted by: Peter Stockwell on 04 January 2004
I'm looking for a supplier of Allen headed cartridge bolts, or failing that the specification that I need so I can get them from a hardware store.
Peter
Posted on: 05 January 2004 by Basil
Try Rega
Posted on: 05 January 2004 by Laurie Saunders
Try RS
Laurie S
Posted on: 05 January 2004 by syd
You could try this guy selling on Ebay.
Mounting Kit
Yours in Music
Syd
Posted on: 05 January 2004 by Mark Dunn
Hi Peter:
In my experience the Rega bolts are the ones to get. They appear to be made of a diffrent material than most others (note their slightly dullish hue) and I've always found it easier to tell when 'enough is enough' when tightening.
Best Regards,
Mark Dunn
Posted on: 06 January 2004 by Peter Stockwell
Thanks for all replies, I had a look over the Rega site, but didn't not specifically see the bolts, but I'll keep looking.
Peter
Posted on: 06 January 2004 by Basil
Send Rega an E-Mail or visit your nearest Rega dealer.
GT Audio
B.P. 59
95420 MAGNY EN VEXIN
France
Tel: +33 1302 72777
Fax: +33 1302 72778
E-Mail: gt.audio@worldonline.fr
Basil,
Thanks for the Rega tip, I'll bear that in mind. I just ordered the fixing kit from the guy on Ebay. £6 + P&P.
Peter
Posted on: 07 January 2004 by Goldstar
Try Linn, the socket headed bolts supplied with my Troika were of the finest quality.
Regards Robert
Posted on: 07 January 2004 by sean
Also try SME or Extreme Phono. Extreme Phono do sell mounting kits and 'non magnetic' mounting bolts, as they put it, as well as other stuff phono. Worth a look anyway.
www.extremephono.com
Sean.
Posted on: 08 January 2004 by Peter Stockwell
Sean,
Thanks for the the Extreme Phono link, They have a turntable mat that looks interesting too. If I have any problem with the Ebay buy, I'll look into Extreme.
Peter
