Cheap wall brackets?
Posted by: wal riley on 26 March 2001
First off, i'm skint so it has to be a cheap solution, but does anyone have any suggestions for fixing the hi-fi to a wall? I've already done this, but with Wickes own-brand brackets; you know, the sort of thing that they use in shops, where a U shaped baton is fixed to the wall, into which clips a sort of right-angled triangular support that you rest the shelf upon. It does the job, with a couple of varnished hardwood shelves, but it doesn't appear to be too rigid from side to side. Any suggestions?
