Reel to Reel (ignore tri post)
Posted by: Mick P on 18 July 2001
Gentlemen
I have always fancied the idea of owning a reel to reel tape deck......the ones with 8" approx diameter spools. I know nothing about them but I do fancy one.
I have a few questions which hopefully some of you may be able to answer.
1. Is it a practical proposition owning one of these things, eg are spares available and can they be repaired etc.
2. How does the sound compare with say a CD3.5
3. Can you plug it into a 82
4. Are you still able to buy tapes.
5. Which is the best model to buy and are there any to avoid.
Your advice would be most welcome.
Mick
[This message was edited by Mick Parry on WEDNESDAY 18 July 2001 at 20:32.]
