USB Flash Drives
Posted by: docmark on 12 December 2009
What are the best USB Flash Drives to use with the HDX? Are they all pretty much the same?
Posted on: 12 December 2009 by PureHifi
Have a read of this thread
http://forums.naim-audio.com/e...2903417/m/9322994627
Your results would be good to add to the discussion..can only suggest you buy one or two and post your results.
Posted on: 12 December 2009 by winkyincanada
Obviously, it will be the most expensive ones!
Posted on: 12 December 2009 by js
This one.
Winker Big Grin
There we go. It sounds more "danceable", even from here!
The data light flashes to the beat. Sounds best when toe is in sync. Smile
Posted on: 12 December 2009 by u5227470736789439
Is this actual, or was Paul Stevens' post [months ago] a spoof?
Today I listened to my iTunes computer playing [music, mainly JS Bach] via a DAC with a USB [by-passing the sound card] converter to spdif optical toslink. Rather good, and such a converter is not expensive.
Nice Naim set in tow, and very listenable.
ATB from George
Posted on: 13 December 2009 by fixedwheel
It was, actually, yesterday. (By 2h54!!)
John
