7.1 - where do the extra 2 speakers go
Posted by: jcs_smith on 02 April 2008
Just wondered where the extra speakers go. I would struggle to get the speakers for a 5.1 system into my fairly large room so 7.1 seems unlikely to be practical
Posted on: 02 April 2008 by Former member
They fire at your ears from the sides.
Posted on: 02 April 2008 by Guido Fawkes
I think 11.1 is where it will go. You need a floor speaker in each corner, two side centres, a front centre and four ceiling speakers in each corner of the room - otherwise you get the feel of the correct height as a plane lifts off.
So it's got to be 11.1 for realism.
I know some folk will say I'm wrong as I've forgotten the upper and lower front centre re-enforcement speakers and the rear centre, but I think that's overkill unless you have a big room, of course.
Now where did I put my shares for those speaker and speaker cable companies.
Posted on: 02 April 2008 by tonym
You're so yesterday, ROTF! 11.5's the modern way to go!
Ideally they should be doing that anyway with a 5.1 system Stuart, with the other two for 7.1 ranged behind you.
Posted on: 04 April 2008 by SAT
Some years ago the BBC did a radio simulcast to go with Tomorrows World where they produced surround sound from stereo. My recollection is that it was way more effective than any 5.1 system that I've heard and this was thro my Briks which as any fule no don't do spacial effects! I seem to remember it sounded ok too. Does anyone else recall this or is my memory playing tricks? I've had 5.1 for some years but my rose tinted specs still think what the BBC achieved was far better.
Posted on: 04 April 2008 by Former member
I saw the program they did,Where you needed to put 3d specs on
Posted on: 05 April 2008 by Bob McC
Was the BBC trial called binaural?
