Motor bike "scottoiler " question
Posted by: David S Patterson on 23 October 2009
Hi, i have run my scottoiler dry, i have refilled the reservoir but cant get the oil flowing to the chain, any ideas
Posted on: 24 October 2009 by full ahead
Did you set the metering valve to prime?
Posted on: 24 October 2009 by David S Patterson
Thanks, i will check that out.I cant see all of the reservoir in situ so will lift it out.
