NAP110
Posted by: Duncan Fullerton on 19 April 2001
This may sound like I'm a dufus, but I've just dusted off my old 32.5 and I was looking for an amp to partner it for a 2nd room system. I'm thinking of a 110.
My Hi-Cap is off on other duties now (82). So does the 32.5 require a Hi-Cap or did I buy it 'cos my 250 couldn't power a pre-amp? I.e. will 32.5/110 work? Help!
Posted on: 19 April 2001 by Andrew Randle
Yes, the 32.5/110 will work. Although I am sure you'll be interested to hear the combination with a Hi-Cap.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Posted on: 19 April 2001 by Phil Sparks
a 110 will power a 32.5 no problem but you need plug in link thingy in the 5-pin din and a snaic 4 from the 4 pin din on the 32.5 to the 110. Using your HiCap you'll have plugged a snaic 5 into the 5 pin din and run this to the HiCap.
Phil
Posted on: 19 April 2001 by Paul Gravett
I've been using the 32.5/110 combination for several years and it sounds excellent. I've just bought a 180, so the 110 is available. Email me on paul@londonaa.demon.co.uk with a tel. no. if possible and you can arrange to come round and hear it.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Posted on: 19 April 2001 by Duncan Fullerton
Thanks for your replies chaps. I'm sure I've seen one of the link plugs lurking around recently, I'll dig it up. Paul, I'll contact you offline.
