Cartridges for the Rega P25
Posted by: John on 26 June 2001
John
John, I have an Elys (purple) on my 25 but I'v heard that the table can do justice to much better cartridges. From Rega you could try the Super Elys or Exact (yellow).
Jay
Dynavector have introduced a limited edition 10x4 Gold (£225) which is superlative. This is a low output MC version of the 10x4 with a boron cantilever like that found on the really expensive cartridges!!! It's an absolute steal and very good value for money, giving a true idea of higher end performance.
Dynavector's 17D2 (£450) is a great little performer with a clean liquid treble. Some detractors say it has too lean a bass response, and it has very low output so you need to turn it up more than some cartridges.
Ortofon's Kontrapunkt A is a fine performer at £500. It's not quite as gobsmackingly good value for money as its bigger 'B' brother, but it's a good one nevertheless.
That's as far as I'd take a P25.
Frank.
By the way I demoed the AudioNote TT2, very disappointing no groove or rhythmn, way below a Rega 25 in my estimation.
John
t
The 10x4 Gold is quite a step up from the standard item.
The low output is caused by less windings in the coils. This usually means that the coils will have less mass and should move faster, giving better transients and detail.
Don't forget the cantilever. This £225 cartridge has a boron cantilever of similar design to that in the Te Kaitora! That's cracking value for money.
But in the end it comes down to what you like. If you really like what the 17D2 did, then my advice would be to wait and save until you can afford it. There are very few cartridges indeed that have the 17d2's liquid treble.
Both 17D2 and 10x4 Gold are best with S boards (or S stageline) I believe.
Frank.
John
