Power amp to go with nait 3
Posted by: Gareth on 11 April 2003
Hello.
I have a CD 3.5 which is hicapped (bought 2nd hand in need of servicing - in the process of arranging), a nait 3 and credos.
My next purchase will be a 2nd hand power amp and convert the nait to a pre-amp.
So I would like to hear your opinions on which would be the best long term purchase taking
in mind that I will eventually get a better pre-amp.
Many thanks
Posted on: 11 April 2003 by Phil Barry
I think you'd be better off economically if you sold the Nait and bought a used preamp. The Nait will probably bring in more cash than a 72 will cost, and you can buy a 32.5, 42, 42.5, 62, 92, or 72 and at least match the Nait's preamp's section.
You might consider hicapping the Nait before buying an amp, too.
Regards.
Phil
Posted on: 11 April 2003 by NB
Garath,
If you are going to keep the Nait as the pre-amp, I would suggest that you aim for at least a 180.
NB
Posted on: 11 April 2003 by Simo
I did'nt know it was possible to hicap a Nait 3 (as Nait 5) how do I do that
cut cut
oh yes, he can hi-cap the nait3 but i don't suggest this, sound came too dark, i had a nait 3/140 combo and imho is better than 72 (without hi-cap) more warm and musical, less treble extension but nice sound....
Posted on: 12 April 2003 by bjorne
cut cut
That sounds really strange to me. I have lived many years with a nait 3r, first bare, then flatcapped and now hicapped and I would say that even the flatcap simply transforms the nait making it a much much better amp, the hicap more so. Maybe it's a "sourceissue" but I really can't imagine anyone preferring an uncapped nait to a capped one. If you go this route you can later use the nait as a preamplifier and add a bigger poweramp.
Per, the nait 3 needs to be converted by a dealer to accept a cap. After that you can use it as an integrated or as a pre.
