CD5i & Nait5i first impressions
Posted by: GrizzlyHippo on 01 January 2004
OK, first off, you need to understand the system I upgraded from: 8yr old Rotel 920AX amp, Rotel 970BX CD, and Keff Coda 7 speakers. I have also been privileged to have Adam's (armered's) vast Naim system 'demonstrated' to me umpteen zillion times over the last 6 years or so. This enabled me to see the benefits of a better Hi-Fi than the Rotel system, but there's no way I could afford a setup like his.
I have had the Naim CD5i, Nait5i and B&W CM2's system up and running for a little over 3 days now.
When it was first switched on it sounded cold and harsh and it felt like I'd made a serious mistake. However, it very quickly got better as everything warmed up and I'm now happy to offer some impressions.
The sound has now settled down. I have played a few tracks on and off since setting it all up to gauge how much the system is changing. The vocals on Blur's Think Tank were really harsh to start with, but now are very well balanced. Pink Floyd's Wish You Were Here is a completely new album. The Stone Roses' Second Coming has offered up totally unheard before depth in the recordings. I am gobsmacked.
The clarity and depth of the sound from this system is amazing. We thought the Rotel was a good setup, but this leaves it in the weeds. I would confidently say that it is MUCH better than similar priced systems that I heard from the likes of Arcam.
My main criticism of these new Naim machines is the remote control handset. Bare with me. This system, while being Naim's 'entry level' setup, is still a very expensive investment for what I presume to be the target market - i.e. Young-ish professionals like me who are upgrading from a Rotel or Arcam system and who never thought they would be able to afford Naim. My setup including speakers cost just under £2k. My previous Rotel setup cost £750. With this in mind I am really dissapointed by the remote control that is supplied as it feels really cheap. It is plastic, really light, and in my opinion, vastly detracts from the user experience. Naim should have provided something like a cut down/smaller Narcom 3 handset, made of metal, feeling nicely weighted and rewarding the purchaser for choosing and entering the world of Naim. As it is, I am constantly reminded of this cheap plasticy handset EVERY time I use the system. It does not make me glad to have bought Naim, which it should do as it is the main user-system interface. I would have been happy to pay another, say £40, to have had a quality handset included.
Don't get me wrong, the sound that this system produces is sublime. Simple. But in my opinion, the handset lets the whole 'first time owner of Naim' experience down.
I hope Naim address the handset issue.
My other (small) complaint is that the fascia of the CD drawer is a different shade of black to the main fascia on the front of the CD5i. Is this intentional, as it looks like a manufacturing / materials mismatch. This problem is not really a problem, but when you sit there for hours, drooling into a bowl, staring at the system, you notice these little things and then they bug you.
Going back to the sound quality, I can simply say that the CD5i and Nait5i perform perfectly together. The sound is balanced, crystal clear, has great depth and clarity, vocals such as Christina Aquilera's Stripped and Nina Simone are gobsmacking, there is bass when needed, but it does not detract from the instruments.
Simply amazing. Well done Naim. Just sort the handset.
Tom
Posted on: 01 January 2004 by Boekster
Naim is about music, not about gadgets (although the Flash seems as if it is able to command an RC racecar
). That's why the remote is perhaps 'cheap'. The Narcoms are plastic as well, but when I use it I skip a number, raise the volume, nothing more. The remotes are fine, layout is okay, and metal does cost extra, and for what? Just forget about the thing and listen to your music!
It does sound like a great system! Just enjoy it, you'll forget about the remote in no time!
Posted on: 01 January 2004 by Mike Hanson
Except for the NAC552 (and formerly the CDS2), all of Naim's gear comes with cheap plastic remotes. Therefore, you're not really being treated any worse than the vast majority of Naim buyers.
I happen to have the Flash that came with my CDS2, which is also a surprisingly terrible remote. (It's heavy, awkward and unintuitive.) Fortunately, I don't need it, as my chair sits within arm's reach of my equipment, hidden in my listening room's closet.
(I did a quick hatchet tweak on the image, so you could actually see the gear.)
If you're interested in a good remote, I can always sell you my old Marantz RC2000 Mk.2. I used it in my home theater until getting a Theater Master MX-700. You can probably nix that idea, though, because the Marantz is top heavy and made of PLASTIC.
-=> Mike Hanson <=-
Posted on: 01 January 2004 by GrizzlyHippo
"I believe the narcom will work with the i units, so there you go just buy one maybe!"
and
"Naim is about music, not about gadgets"
Sorry guys, you're missing my point. I am enjoying the music more than you can clearly imagine, and I know I can go and buy a Narcom 3, but the point is that for a little extra, Naim could have delivered a perfect package, straight out of the box.
That's all. Simple.
Posted on: 01 January 2004 by JeremyD
Flabbergasted
Posted on: 01 January 2004 by HTK
The remote which came with my CD5 is the most nasty bit of brittle rubbish I have ever seen. So I just hid it somewhere and made a fuss of my ears! Turned out that the old Marantz CD94 remote worked fine but I don't mind the walk. It's always rewarding.
If my CD5/HiCap is anything to go buy - if you think it sounds good after 3 days, just wait until this time next week. You ain't heard nothing yet (this observation is much disputed and probably depends on lots of factors).
Harry
Posted on: 01 January 2004 by dave simpson
Personally, I'd rather have all the manufacturing dollars spent in the box (vs. the remote)....it makes more sound;-)
regards,
dave
Hi Dave,
"Personally, I'd rather have all the manufacturing dollars spent in the box (vs. the remote)....it makes more sound;-)"
I completely agree. Just thought Naim could do with the handset feedback. Having been involved in manufacturing, I know it wouldn't take much to add some simple weight to the handset. That alone would make it feel better.
Gorgeous system though. The only real problem is that I'll have to sell our 5 month old child into slavery as I'm sure to want a more advanced Naim system in the future.
Tom
Having been involved in manufacturing, I know it wouldn't take much to add some simple weight to the handset. That alone would make it feel better.Hi Tom,
I completely understand....funny, when I first purchased my CDS (mk. 1), I loved it's chunky remote. I much preferred it over the new (cheezy) remote supplied with my 102. With time though, I find myself preferring the 102 remote over the chunky CDS unit. The extra space between buttons and color-coding makes it easier to operate in the dark (what with reading glasses a required item now;-)
regards,
dave
Posted on: 01 January 2004 by Mr_Sukebe
Guess there's two ways to think about the handset:
1. It's cheap and crap and I want more
2. Naim saved money on the handset which is why the CD5i/Nait 5i are both much cheaper. With the cash I've saved I'll buy myself a very tasty Philips Pronto from RS.
Posted on: 01 January 2004 by London Lad
How much is a flash 2 ?
BTW is the a FULL Naim price list anywhere ?
Graham.
Not a lad any longer and not from London!
Posted on: 01 January 2004 by David Stewart
John,
The OneForAll website here
http://ofausa.com/ has a smart multimedia demo of the latest 8in1 Kameleon (URC9960), which is a far more attractive beast (IMO) than the previous incarnation, but doesn't yet appear to be available anywhere in the UK.
I was thinking of asking friends in the USA to get one for me but am a bit put off by user comments of poor battery life, ultra-sensitive backlight switching and too-short timeouts on the backlighting - how have you found yours in these respects?
You want to pay for looks? The NARCOM is functional IMHO, and it feels as cheap as most remotes I've had and have seen. The true exception comming from Densen. The remote is full Aluminium and wheighs a ton. Nice to lift e brick each time to skip a track. Quit complaining, it works doesn't it? I hardly use the thing. I haven't seen the Flash remote so I can't judge it. And yes, some brands do deliver good remotes. Naim does the same. Other people do have different opinion.
I do have to agree with some opinions, that it does make a statement. Akthough once you get back into your music, to hell with te remote! Just sit back, and enjoy the music!
Cheers!
Posted on: 01 January 2004 by Geoff P
As a typical home media user I have remotes coming out my ears. What with Home cinema, digi box, TV, VCR, and of course Naim.
I agree with everybody!!
1) A smart heavyweight remote makes a statement (eg the CHORD metal billiet)
2) One that glows in the dark is usefull for late night listening / viewing
3) A multi-device one sounds great
4) A cheap plastic remote that works even though it's no great shakes to handle is still OK especially if the money saved really deos show up in the electronics.
BUT They all suffer from the same effects
1)They all get lost down the sofa.
2)You find yourself accidentally setting the VCR to record when you meant to change tracks on a CD, when you have them all lying beside each other.
3)Biggest problem is finding the right "mute" button when the telephone rings.
Having said all that you end up paying out money for a real universal remote like the Pronto which can cook your dinner for you aswell.
...AND You have to get up to turn the record over anyway!!
GEOFF
I agree with those who say the quality of the remote doesn't make a dime of difference to the quality of the music, but when your expensive Naim HiFi comes with a tacky little remote not much better than that supplied with the cheapest TV, it doesn't do a lot for the product's image.
Suggestion for Product Development - do an OEM deal with OneForAll and a have a custom Kameleon designed with a black surround, and green back-lighting. That way we can all proudly show-off how our stylish Naim remote can control the whole domestic AV experience.
Posted on: 01 January 2004 by garyi
I must say I loved the remotes from the likes of Meriden.
That remote My Toon, do you point your devise at it too learn?
Posted on: 01 January 2004 by Mike in PA, USA
These are all very good comments. My own expreience, having just hooked up my CD5 and Nait5 is similary to Grizzly's in terms of sonics (I opted for the non-"i" models as I wanted a little more input capacity and upgrade potential), but I also see what he is saying about the remote. From a "consumer product" perspective, the remote IS the place where customers most frequently interact with the product -- much more than, say, the capacitors.
The interesting this is that I had considered putting in a Rotel 5.1 system instead of the Naim gear, and had a Rotel 1055 receiver at home on demo. Now that piece of equipment had an AWESOME remote. Controlled all the Rotel gear, could learn other manufacturer's codes, had an LCD display, and the buttons glowed in the dark.
The problem was that the receiver sounded like poop, and for the cost of that receiver, a center channel speaker, and a pair of rear channel speakers, I was able to get the Niam 2-channel rig, which sounds golden and is true audiophile gear. So I suppose there won't be any explosions behind me, but that won't keep Dave Mattews from performing in my living room.
Cheers and Happy New Year all,
Mike
Would anyone know of a cheap site to order Johns version from, I have found them at £69 so far.
Posted on: 01 January 2004 by Greg Beatty
I'll toss in a vote for the Home Theatre Master MX-500.
Controls up to 10 devices
Each device has 10 custom labelable (is that a word?) via an LCD
The device buttons are easily programmable with a macro to switch the video and audio in your system to the chosen device - this is a marriage saver for those of us with spouses who might prefer the simplicity of an "All In One" system
Built like a tank and rubberized texture feels great
Lights up
Powerful - I can aim this thing backwards or use it from an adjoining room with no problems
Very reasonable price ($125 US)
Its the LP12 of remotes. Check out remotecentral.com for more on remotes.
- GregB
Insert Witty Signature Line Here
Each device has 10 custom labelable (is that a word?) buttons via an LCD
Lights up
- GregB
What David said and remembering that even a "cheap" Naim box is probably relatively expensive for the target customer segment. That Kameleon looks ever so nice - might solve a few problems.
Hary (who still answers one of the many remotes laying about when the phone rings).
Posted on: 01 January 2004 by Tuan
Posted on: 02 January 2004 by GML
Thanks for the input Tom, just what I wanted to hear.
Posted on: 02 January 2004 by Top Cat
Remotes... hmmm...
What a joke that is... The Naim remote control is the worst control system. The cheap ones look CHEAP and feel CHEAP. The most expensive one (they call it FLASH) is expensive and confusing.
I think the Naim plastic remote I have for my 82 is fine - though I think the layout isn't the most thought out design and I keep picking it up the wrong way around
Used a Flash and it was 'orrid. Well built, sure, but horrible.
That said, I recently tried a Rogue Audio Magunum 99 preamp which comes with a lovely remote made of aluminium - even down to the buttons. However, it was infinitely worse than the Naim 82 remote, as (a) the button feel was really bad, and (b) it barely worked, even with fresh batteries - you had to 'stab' at the buttons, as holding the volume button did nothing. SO, to increase volume substantially required several presses of the buttons. Not good.
Glad I could give it back in the end.
What remote did the 52 come with? I'm going there soon, just wondered if it was a different remote to that of the 82...
John
TC '..'"
Sun went down in honey. Moon came up in wine. Stars were spinnin' dizzy, Lord, the band kept us so busy we forgot about the time."
Posted on: 02 January 2004 by garyi
Thanks John for the idea, I have got a 6in1 now and its fantastic. I have programmed one of the buttons to turn the amp to the TV input and turn the TV and the SKY on, excellent stuff!
Posted on: 02 January 2004 by JeremyD
I must admit that I don't like any of my remotes, including my Naim one - but I wouldn't dream of taking the quality of the remote into consideration when buying hi-fi.
My ideal remote:
1) Doesn't need precise aiming.
2) Fits the hand in such a way that one can reach all keys with the thumb without having to move the remote in the hand. The space between the keys on most remotes is huge - I find it difficult to believe this helps anyone.
3) Has keys with a positive feel.
4) Has logically designed control functions.
If someone could make a remote that resembled a Casio calculator I'd probably be delighted with it!
