what digital camera
Posted by: jason.g on 07 January 2004
i have approx £200 to spend (maybe £250 max) on a digi camera. i would like at least 3m pixels and an optical zoom. my favourite at the minute is the new nikon coolpix 3700 at £250.it has 3 x optical, 3.2m pixels, rechargeable and audio facility for short movies.only downside is a small 16(?) memory card. what is out there of similar quality with better memory? any useful online sites?
what were barn owls called before barns were invented?
Posted on: 07 January 2004 by Former member
Jason
The Nikon Coolpix is the right choice, they have the best lens.
Posted on: 07 January 2004 by Rasher
I have a Nikon Coolpix 3700 and it is totally brilliant - except that the batteries don't last very long between charges. If I lost it, I would buy exactly the same again - no question.
I bought a 64mb compact flash card in the USA for not much money, but you can get a 128mb card from www.novatech.co.uk for only £25 or a 64mb for £15. Yes..really.
Posted on: 07 January 2004 by count.d
PR is correct again. You should listen to this man.
Although I would go for the Coolpix 4300. This place sells it for a good price:
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=51702&_LOC=UK
The Coolpix 4300 is a bit bigger & bulkier, and I looked at this when I bought my 3700. I decided that for what I was using it for, 3.2 megpix was more than enough and the smaller size made it more pocketable, which was the most significant consideration in my case.
Posted on: 07 January 2004 by Eddie Pugh
The Canon Ixus 400 would get my vote. It is really good and is also small and convenient but it might be a bit more money.
Ever since my wife bought the Ixus I've almost stopped using my Olympus OM gear and my Canon G3 is gathering dust
Eddie
Eddie
Posted on: 07 January 2004 by jason.g
the tiny ixus was my other choice but it is just outside my price range. the nikon 3700 seems to have covered everything the 3100 was missing. audio facility, more ergonomic and sturdy case, noise reactive self timer etc. it,s just finding the best deal now. bit dubious about these ebay dealers who ship from hong kong. loads of hidded costs etc. keep the advice coming cheers.
My mistake - I have a 3100, not a 3700
. Still - great camera
Posted on: 07 January 2004 by Steve O
I've just bought the Olympus Myu 400 - it's a belter.
4MP, small, light and stylish - plus an added benefit is it takes cracking good piccies!
Retails for £329, but I took printouts from the websites of Dixons and Amazon, who offer the camera for £229 and Jessops did a price-match. This leaves some spare dosh to upgrade the memory card. But don't tell 'em I told you.
Steve.
Steve.
Posted on: 07 January 2004 by David Stewart
Before you decide, take a look at the Canon A70 here http://www.dpreview.com/reviews/specs/Canon/canon_a70.asp particularly the user reviews - it might just convert you from the Nikon.
Posted on: 07 January 2004 by long-time-dead
Owls ?
I'll place a vote for the lens quality of the Nikons. I use a coolpix 900 and at high res it's a belter. I've used other cameras and prefer the images from the Nikon - they look less "digital"
But you pay your money and take your choice....
Posted on: 08 January 2004 by greeny
Please make sure you try before you buy. There are considerations such as start up time and shutter delay that may be important to you (If you are going to take action shots for example). Also some have very 'interesting' ways of implementing manual focus.
Posted on: 08 January 2004 by David Stewart
Interestingly enough, DP Review include a lot of timing data in their full camera reports, which are generally very helpful, providing you're experienced enough to be able to interpret them. Not so easy for a beginner though.
Posted on: 08 January 2004 by Former member
long-time-dead
Exactly! The Nikon lenses are the best, especially when so small. Less light, means less colour/image definition.
For example: Sorry it might load slow
Nikon Coolpix (Digital)
Nikon F80 (analogue 35-110)
The colours are richer on analogue due to its bigger/higher quality lens.
Posted on: 08 January 2004 by Derek Wright
Do not think that you have proved your point
The analog picture would have been taken with a daylight type film. The digital was taken with a camera that has auto colour balance. (Unless you had set it to say 5500K for bright sunlight)
The pictures (based on the analog image) were taken late in the day hence the warm colours in the analog image whereas the digital camera had adjusted the colour sensivity to normal. Hence removing the warmth and some of the richness
Also the analog image does not contain a significant area of shadow which on the digital image will have caused the digital camera to attempt to compensate by increasing the exposure and reducing the saturation of the colours.
Also you do not say whether you used a polarising filter which tends to increase colour saturation - I think that you might have done due to the change in blue sky density across the image.
So I say that your point is not proven
See here for a saturated digital image
Derek
Derek
Derek
I agree with your point in principle, even though assumptive. Both camera's were used with standard settings with pictures taken at the same time, though slight differences in position. However, I tried all settings on the digital, and could not produce the correct colours, as so easily achieved with the analogue.
The digital is excellent, but the Nikon F80 just does it for me
You want to see this on film!
DId you have the colour temp on the digital on auto or preset - presetting to 5500 for sunset type pictures and underexposing gives the results I want.
Derek
Derek
Posted on: 08 January 2004 by count.d
Digital one seems alright to me.
Count D
Please describe what corrections you did to the digital image
Derek
Derek
Posted on: 08 January 2004 by matthewr
Virtually no meaningful information about relative performance of the two cameras, let alone film vs digital, can be gleaned from the pictures posted. Least of all anything to do with colour rendition and saturation where there are like a gazillion variables in the two processes that led to the above images.
Also its a bit pointless to talk about an F80 when what really matters is the lens. In fact if its got some dodgy cheapo super-zoom it might even be worse than the better Coolpix lenses in pure optical terms.
Matthew
Matthew
Posted on: 08 January 2004 by Steve O
PR,
I have studied the two photo's very carefully and for me the digital camera is obviously the better one as it hasn't killed all the plants.
Steve.
Steve.
count d
The digital pictures look slightly soulless to me even colour enhanced.
Derek,
Generally, I masked everything off below the sky and adjusted colour balance by adding red and yellow, then saturated it. The sky was saturated aswell, but not as much.
I shaded all the corners, lightened the ground and plant's highlights, diffused glow the whole lot and despeckled the sky only.
PR, I see what you mean, but I can't comment as I don't have both the originals at hi-res. On the image I retouched, after compressing it down again to under 50kb it looks pretty bad. If you look at the mountains, they're blocking up with magenta colours.
The only real problems I have with digital are irretrievably bleached out highlights and skin tones being over saturated. Skin tones are a pain to get back looking right.
count.d
You are right.
For some reason digital prints remind me of CD. Perfect on the surface, but lacking that final touch that gives the tingle factor. Maybe grit and grind is good for our soul.
You are right.
Posted on: 09 January 2004 by Derek Wright
Count.d
Thanks for the detail
PR - Photography has been going down hill ever since the introduction of roll film - if you want quality you need 10by 8 b&w negs to get the best colours <g>
I expected your CD versus vynil comparison after your "soul" comment.
Derek
Derek
