Flutterbuster on Rega P3?
Posted by: domfjbrown on 29 September 2003
I've just scored a Flutterbuster for my Rega Planar 3 - but I've had a horrible thought. What if the motor upgrade I have had done (taking the Planar to P3 status) is incompatible with the Flutterbuster?
I'm assuming all is fine as the new motor is still a syncronous type but with a more refined PSU - is this true?
I got the Flutterbuster as I'm sick and tired of having to dismantle the deck when playing tunes. Since I've got into psy-trance recently and thus a lot is on 12 inch 45rpm, I'm usually fairly mullered when playing this stuff. Dismantling that Rega when sober is bad enough (I'm parially sighted - so find centring the platter is a PITA - though cueing up vinyl is easy) so I want the electronic speed change.
Have I messed up, or can I wire in and go with confidence?
Also, do you have to turn the deck itself off before changing speed (assume so to prevent wear on the motor/belt), and which pully should the belt be on - I'm guessing the 33 setting?
Thanks in advance peoples!
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
