Email hosting and a grump
Posted by: Mike Hughes on 10 December 2006
Okay first problem. I have just moved to a decent speed broadband, which is great, but my ISP email is non-existent. I would like to continue to use Outlook as a client but I am moving toward buying my own domain and getting it hosted. So, anybody able to reccommend some decent, cheap hosting for someone in the Manchester area?
Secondly, a grump. Naim, this site works beautifully to view in Firefox but whenever you want to post something you have to use IE tab or IE itself. This is the 21st century. Could it be sorted please?
Mike
Posted on: 10 December 2006 by Diccus62
I use Firefox and have no problems posting. Are you using the up to date Firefox?
Diccus
Posted on: 10 December 2006 by Deane F
Yes, that is weird. I have used nothing but Firefox on this forum since a couple of months after joining.
Deane
It's above my level then. Wait till the techies are online
Diccus
Posted on: 14 December 2006 by Mike Hughes
Yup, I am using FF 2.0. I can do a quick reply but not a full one.
Mike
... and email hosting???
Mike
Posted on: 15 December 2006 by Paul Hutchings
I have a domain with
Nameroute which I don't do a lot with, but it seems to work fine and is cheap.
Have a look at
Black Cat Networks too, not as cheap but they seem well regarded.
Most domain name registrars will do basic email forwarding, so if your ISP provides email but you're the highly memorable ag23xhg@isp.co.uk you could simply register a domain name and get it forwarded.
Posted on: 15 December 2006 by SteveGa
Re Firefox - It must be something turned off in Firefox, probably in tools - options. I seem to remember turning Java off and not being able to do anything on this forum. See if Javascript and Java are enabled. Just a thought.
Re Hosting. Nowadays this is very much a host anywhere business. As others have suggested I would register a domain and then host it somewhere (you might try
SiteHQ who offer 100mb of space and 50 pop accounts for £30 per year), then forward all e-mails from your ISP to your brand spanking e-mail address.
Or of course you could host it yourself ... no too much beer too early in the evening!
Steve
