All is revealed: What the numbers actually mean.
Posted by: silklee on 07 April 2003
Ok guys,
we got it all sorted out. The mystery has been solved.
Have you been wondering what the numbers actually mean. No need to crack your brains anymore. We got it all worked out.
Basically to calculate where your system stands in the Naim hierarchy, just take the model numbers that you have and add them up, except for 'X' mean multiply and 'S' means square.
Therefore if you have a CD5/112/150, it is basically 5+112+150 = 267.
If you have a CDX2/202/200, it is basically (202+200)*2 = 804.
However if you have a CDS2/82/180, its (82+180)^2 = 68644.
You can imagine what CDS3/552/500 will give you.
Get it? Its so simple. This falls in nicely with the source first theory, doesnt it.
Posted on: 07 April 2003 by garyi
what about a CDi?
A nice source componant often compared to the CDX.
Common, you got to get with the winning team here.
Posted on: 07 April 2003 by rch
Oh, by the way,
and don't forget to consider the different types of pucks!!
Christian
Posted on: 07 April 2003 by Greg Beatty
"what about a CDi?"
No problemo - the 'i' stands for 'imiaginary' - which is the case with CDi's here in the states.
- GregB
Insert Witty Signature Line Here
Posted on: 07 April 2003 by David Stewart
I suspect this thread started six days late Smile
Posted on: 08 April 2003 by NB
And what do you get for a Fraim? Razz
NB
Posted on: 08 April 2003 by Martin Payne
Using the CDS2 rule:- 806404.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
