Prefix wiring.
Posted by: Mario on 13 October 2003
Hello all.
I am condidering a prefix to replace my stageline on my LP12. Even though I will get my dealer to install it, I am a bit lost about the diagram on the naim website. I understand that there is a cable that attaches to the the base of the tone arm and another cable that comes out of the turntable that goes to a power supply or a powered aux 2 input on a suitable preamp. The confusion is with the extra wire that appears to be cable tied to the snaic that exits the LP12's plinth. I imagine that this is an earth wire and that it remains inside the turntable, but the diagram looks like it has the wire leaving the plinth as well as the snaic. If it does exit the plinth, what would you connect it to? Is the diagram on the website a bit misleading or am I just unaware of something very obvious? Can any prefix owners shed any light? My Lp12 has an Ekos, XX2 and a Lingo power supply.
Regards Mario.
Regards Mario.
