Computer help please...
Posted by: Webke on 05 April 2005
When brousing most sites, the fonts seem to be much larger than what they used to be, one of the sites affected is this naim forum, when I use other computers the fonts seem to be much smaller and better to read.
I was wondering if anyone knows how i can change this seeting perhaps?
Many thanks for your time.
Posted on: 05 April 2005 by TomK
If you're using IE, take the View menu and you'll see an item called Text Size. Adjust that to your preference. Can't remember what the Firefox equivalent is as I'm at work at the moment. Other browsers will have something similar.
Posted on: 05 April 2005 by Webke
Tom, many thanks for your response, problem solved!
Posted on: 05 April 2005 by Two-Sheds
Also if you have a wheel mouse holding CTRL and using the wheel will zoom in and out. This works in most windows applications (IE, Firefox, Word etc.)
Posted on: 06 April 2005 by Deane F
My god! I never knew that! It's actually a little spooky.
Posted on: 06 April 2005 by TomK
Two-Sheds well I'll be buggered. You live and learn. That's an impressive trick!
