HDX network shares - useful info...
Posted by: Billy Rubin on 11 September 2010
I've posted this elsewhere but thought starting a new thread might increase visibility and help others.
The HDX seems to be rather particular regarding the folder structure for music on network *shares*.
My experience is that the folder structure *must* be artist name > album name > tracks
For example, if you have only one track by a particular artist, the above folder structure still needs to be adhered to.
So:
Juliana Reyes (artist) > Slowly (track title)
won't work, but
Juliana Reyes (artist) > Dominos (album title) > Slowly (track title)
is OK.
It also seems that the presence of certain non-alphanumeric characters within the names of any of these folders will cause the HDX to simply ignore the entry completely.
For example, "The Beatles 24-48" seems to be OK, but "The Beatles 24/48" is not (I use this example as I have marked my high resolution content with this kind of a notation).
Although I haven't read the manual from literally from cover to cover, I have skimmed it and I haven't seen this explained anywhere. Probably needs a note in a future revision. Would have saved me some time...
Posted on: 11 September 2010 by Aleg
The HDX being based on the Windows operating system I can imagine that the following characters or forbidden to be used in file and directory names (since this is so in Windows): "/\*?<>|:
Possibly these character can be used on a NAS since these are mostly based on Linux which allows most of these characters.
aleg
Posted on: 12 September 2010 by David Dever
No, keep it simple as the HDX still needs to read SMB/CIFS-compatible directories / filenames.
Posted on: 12 September 2010 by Aleg
You are right, and it is also what I meant to say.
One shouldn't use any of the forbidden characters even though a NAS would allow them, because it is a Windows-based system that needs to read them and that can't handle them.
So don't use any of the forbidden characters.
aleg
