interconnects
Posted by: minime on 19 September 2002
anyone ever tried dnm reson ic,s what do you think?
Posted on: 19 September 2002 by Top Cat
The DNM/Reson ICs work well - I used a Phono->DIN cable for a while, whilst I was hunting around for a better cable (for the main system I have to add). It's leaner than the standard Naim cable I have though I think it's more detailed. The speaker wire is similar over A5, though I chose A5 for it's rabbit-proof properties.
It's good value stuff, and even in a system in which cable choice is not as straightforward, it can reap great benefits. You'd have to move to something like Nordost Blue Heaven, at around 6 times the price, to achieve a worthwhile improvement over the DNM cable IME.
My only recommendation is that care is taken not to bend it too sharply, as being a solid core cable it is possible to break the core - this happened to my dealer once whilst setting up a demo for me, but luckily it was the plugs' connection which meant that only a small amount of cable was lost. So be warned... wink
TC '..'
"Girl, you thought he was a man, but he was a Muffin..."
