what does 'k' stand for?
Posted by: Phill82 on 06 February 2004
Could anybody just tell me what makes my Nac72 a nac72'k'.
Phillip
Posted on: 06 February 2004 by starbuck
I think the K stands for the type of phono boards installed - 'K' boards being for low output moving coil cartrs ala Linn.
Hope that helps.
Posted on: 06 February 2004 by Phil Sparks
Yep there were/are two types of boards for moving coil cartridges - the standard ones (known as 'S' boards) and ones optimised for Linn moving coil cartridges. They were first produced when Linn's best MC cartridge was the Karma - hence the 'K'
Phil
Posted on: 06 February 2004 by Noel
Phillip,
Phil is right. It's worth knowing that the 'S' and 'K' boards are interchangeable for many moving coil cartridges, its just that the 'K' was optimised for the asaK, asaKa, Karma, TroiKa etc produced by Linn.
Noel. Smile
Posted on: 06 February 2004 by Carl Leermakers
Phil, Noel,
Is the "K" the appopriate board for all Linn MC's (Klyde for example)?
And now for a very stupid question (sorry Richard Smile): when you get a prefix, do you also have the choice between 'S' and 'K'? Do the come with the prefix or can/must you get them separately?
Posted on: 06 February 2004 by Basil
Originally posted by Noel:
Phillip,
Noel. Smile
Just what was it with Ivor and the letter "K" anyway????
Posted on: 06 February 2004 by BigH47
He had been influenced by Kinks who spelt every thing possible with a K.
Howard
Posted on: 06 February 2004 by Chris Metcalfe
Apparently also the Stageline is also available in 'S' or 'K' mode.
So if 'S' = standard and 'K' = Karma, what does 'N' for Moving-magnet stand for (Normal?) ?
Posted on: 06 February 2004 by fatcat
Phillip
Have you had the amp from new. If not, you may not have K boards fitted. It may be worth checking the boards.
I use a DL103 and find there is little difference between K and S boards.
K boards will basically livening up a dull cartridge, S boards will mellow a bright cartridge. I suppose a neutral cartridge works well with both.
(I think Ive got the above the right way around)
Fatcat
