Two dvd players to an AV/2?
Posted by: crsm on 28 December 2008
Hi,
Can I connect two dvd players and a Sky HD box to an AV2 and if so which input source component should be used for the second DVD player?
Cheers!
Richard
Posted on: 28 December 2008 by SC
Well as I understand it, there are x2 Coax and x2 optical inputs, and then there are a set of analogue inputs also. So you have 5 choices there....Coax is probably your best choice with a decent cable...
Posted on: 29 December 2008 by AV@naim
see AV2 manual here:
http://www.naim-audio.com/products/intro_manuals.html
Posted on: 29 December 2008 by crsm
Thanks,
Richard
