Alfredo Perl Plays Beethoven
Posted by: Todd A on 02 July 2005
Yes, another cycle. I’ve been aware of this long-box for years, but never got around to buying it. It’d be around, I thought. But when I started looking around the web recently, the cheap ($50 for 10 discs) set was impossible to find. It appears that Oehms snagged the rights to the recordings and now sells them at a higher price – about 75 Euros. (Perhaps the Oehms set is a new cycle, too; I don’t know. Anyone?) I remembered seeing the Arte Nova box at the local CD hut, so when last I went shopping I kept my eye out. ‘Twas there. I bought it.
Remarkably unremarkable. That’s the best way to sum up the first sonatas. Perl offers little to nothing in the way of interpretive idiosyncrasy; he opts to let the music speak for itself. That’s not to say that he plays in a cold, analytical way, but rather that those insights he offers are subtle and at the service of the music. As such, at least with the Op 2 sonatas, there’s precious little to comment on. Slow movements are slow and fast movements are fast. Nothing is exaggerated. Nothing is underscored. Everything is just direct, clean, and refreshing – the musical equivalent of a glass of fresh, cold water. Okay, he does allow himself a bit of leeway in the final movement of the second sonata, playing some of the music with just a tad of (attractive) thickness and slowness, but it’s subtle. His individuality starts to peak through just a bit more in the third sonata, where two things become evident. First, he doesn’t rush the music. He takes his time and lets it unfold. At over 28’, this is a long recording of this work, yet it never sounds sluggish. That’s because of evident item number two: Perl has a spiffy rhythmic sense. Even in the Adagio, which he plays with a bit more heft, richness, and foreshadowing of later Beethoven than may be the norm, he maintains a nicely sprung sound. No, he can’t quite match the nearly peerless Gulda, but Gulda’s the only pianist in my recent listening who bests him here. Perl brings out some more playful elements in the Scherzo and final movement as appropriate, but to an extent, even with his now identifiable traits, his playing is about the music first and the pianist a distant second.
The Op 7 sonata merely reiterates this. The opening movement is played swiftly, with a great deal of brio, as it should be. Perl’s rhythmic sureness generates a nicely groovy feel, and makes for one finely played opener. The second movement is definitely taken at a Largo pace, and even though Perl doesn’t shy away from spending his time on the movement, his sense of rhythm cannot be hidden. How does he make the movement keep such a nicely rhythmic feel? Dunno. I just like the result. The last two movements show off his strengths well and really animate the piece. Perhaps something else shows up, too: Perl is, by and large, serious. While lighter moments appear, and softer playing is to be heard whenever and wherever appropriate, this is some serious business. I like my Beethoven serious. That just helps out this young pianist’s cause.
The three Op 10 sonatas more or less continue on as the preceding works. The last of the sonatas highlights Perl’s penchant for occasional slowness, especially in the Largo. A few times he just brings the whole thing to a stop, craftily utilizing pauses. The Adagio to the first of the bunch is slow – but not as slow, as one would hope, though it displays many of the same traits as well as some drama. The lighter, quicker movements all come off very well. One is reminded that not all of the swift music needs be pounded out at high volumes; Perl uses a varying touch, sometimes playing with strength, other times with a supple touch, but the one constant is that it feels right. Whether one considers the delightful little Presto ending the F major or dashing and delightful Prestissimo ending and brisk, athletic opening to the C minor, or, well, anything, everything just seems right. No flash, no undue seriousness, no out of place humor. It’s just solid playing.
The Pathetique again continues on with the strengths of the earlier works, but adds a bit of flexibility to the mix. If his interpretation is not the most passionate and strongest out there, Perl still delivers a forceful reading with some remarkably alert, nimble playing, and he accomplishes this without a hint of strain or bang. The opening movement flies by with superbly articulate runs and exciting crescendos as does the finale, and the middle movement offers a nice bit of contemplative rest, as it were. Others go deeper, and some are too melodramatic, but Perl plays it as an essentially early piece, which it is; this is not cut from the Eroica cloth. It pre-dates it. I remember this sonata being good, and now I can confirm it.
The two Op 14 sonatas continue the winning streak to ten straight. The first sonata is fast and sprightly, perhaps just a tad too much so in the Allegretto second movement. But any quibbles are minor. Perl’s playing is light enough and fun enough and really animates the piece. The G major sonata is something else, though; it is a masterly reading, or almost one. From start to finish this recording is all about charm, and Perl brandishes a nicely flexible and rounded tone, and jettisons the seriousness for a bit. No, he’s not nonchalant, and he’s certainly not sloppy, but he plays with controlled tempi and nicely restrained but obvious enthusiasm. The opening is pure delight, and the following Andante is an adroit mix of charm and beauty and winking wit. The concluding Scherzo caps it all off. This is a winner, and perhaps the strongest recording of the set thus far.
So, another fine cycle is under way. Perl may lack the flash of some, the power of others, or some other traits that people crave; I can think of more poetic readings, more virtuosic reading, more aggressive readings, but I can think of no set of the first ten recordings that are this straight-forward and unaffected. That’s not to say that Perl plays in a boring or pedantic manner, but just that he obviously enjoys the music and has enough trust in Beethoven’s music to let it be the sole focus. Perl has his unique traits, but they’re of secondary importance. As to sound quality, these recording reveal their vintage: they are from the early 90s and on a budget label. They can sound a bit glassy at times, and lack some warmth. They also sound a bit more distant and resonant than I prefer, but overall the sound is much more than acceptable. I certainly hope the rest of the cycle is this good.
