Flatcap or HICAP
Posted by: alex95 on 16 July 2003
Was wondering, does a 3 yr old hicap sound better than a new fc2 n a CD5o
Posted on: 16 July 2003 by Steve Toy
A 3 year-old Hi-cap WILL sound better than a new FC2 into a CD5.
Steve.
Posted on: 16 July 2003 by jcc
Yes it will sound a 'bit' better, but what is the rest of your system? A fc2 works wonders on a CD5, plus you have the option of providing power to another 'device'.
cheers,
jim
Posted on: 17 July 2003 by Dan M
Julian,
I'm surprised by your finding - my understanding is that the FC2 is just a FC1 with two extra regulators and an additional winding on the transformer. Could the improvement be down to the case?
-Dan
Posted on: 18 July 2003 by Frank Abela
Yes, this is all true, but if alex95 has a 112 or Nait5, then the fc2 will bring about greater overall benefits since it sorts out his preamp as well. He can always add a hicap later which will improve things no end later.
Come to think of it he can do this with his preamp irrespective of which one he's driving! So I would go fc2. The only exception is earlier Naits. I wouldn't go to the bother of having the Nait modified to accept the *cap input. It's a personal thing - I just don't like modifying Naits.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 18 July 2003 by Mr Perceptive
Gentlemen
To add to the discussion, I have a 62 pre-amp which I am considering adding an external PSU to. In the 62 when it is connected to a HiCap, one 24v rail supplies the phono stages (only) and the other the rest of the pre-amp. Now I have modified the unit to remove the phono stages and created another line level input (equivalent to some 326 cards).
Would I be best to run this with a SNAPS or FC1 or will I see a further improvement when using a HiCap, even though I would only be using one rail of the HiCaps two outputs ???
Mr Perceptive
Posted on: 18 July 2003 by novelty
depends on what you are using the second output of the fc2 for but generally yes the HC will have a larger impact on your system..
"So what ya gonna do when the novelty has gone.."
