I'm looking at the Trichord Dino (and later power upgrade) or the Tom Evans Microgroove (and later + upgrade)- or maybe some other alternatives that I am unaware of in this price area.
I can certainly vouch for the bog standard Microgroove, even though I have only had mine a week it is sounding pretty damn good. It gives a big, open, clear, and groovy portrayal of the music with IMHO little not to like. Make sure its warmed up - I had to make a big leap of faith based on a cold dem, though I'm happy I did. From cold it sounds thin, pinched, and shut in, though leaves you in no doubt about its timing abilities. As mine burns in it seems to randomly move a little between jaw droppingly good and very much less so, obviously I hope it settles at the right end of the graph!
I have heard the Trichord sound very good in someone else's system too, and for 300 quid I reckon it is probably the one to have, I like the way you can adjust the loading and gain with this model, something that is not possible with the Microgroove. I bet the Microgroove is well worth the extra hundred quid though, and from a very quick exposure to a cold Microgroove Plus I suspect that is something very special indeed. I reserve the right to upgrade mine later on.
You order the Microgroove to match your cartridge, my Ortofon MC25FL is sort of generic MC in spec, so I guess my Microgroove is as bog standard as they come. It does however have tons of gain, probably more than I would ideally like given how twitchy my amps volume knob is. It is really quiet noise wise, and I bet it would work well with the low output Dynies - I tried a 17D2 and an XX1L with 323 boards in a 32.5, and felt that I was seriously lacking adequate gain, it was almost certainly due to this that I formed a dim view of both cartridge. I would love to hear them again via a more suitable stage.
Tony.
