Help Needed - Nait 2 / Sky+Cable
Posted by: Ails on 03 May 2008
Hi
I am thinking of connecting a Sky+ box to my Nait 2 so that I can play the sound through some Kef speakers. Can anyone suggest what type/spec of cable I need to purchase to connect the 2 units.
Thanks in advance.
Posted on: 04 May 2008 by james n
You just need a phono to DIN cable. Chord Crimson should do the trick
2RCA-5pin DIN
rgds
James
Posted on: 04 May 2008 by Ails
Thanks for your help James - much appreciated
Posted on: 10 May 2008 by Ails
Hi
Is it better to connect the cable to the Sky box or to the TV in terms of the quality of the sound that is output at the speakers ?
Posted on: 10 May 2008 by james n
Straight out of the Sky box will be fine.
James
Thanks again James
